trany mount and skid plate - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > trany mount and skid plate
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 03-12-2012, 09:29 AM   #1
YJmaddness
In this weekends adventure I managed to get both front wheels in the air and some hard drops on my skid plate. Now I am in need of a trany mount and possible skid plate.
Where should I get these? Anything I need to avoid?
Ill get some photos up tonight.
YJmaddness is offline   Reply With Quote
Unread 03-12-2012, 09:36 AM   #2
Louie4
Injanir
Louie4's Avatar
I used a GM poly mount and got a new skid plate from a buddy who did a tummy tuck. I know UCF sells some good ones. I've also seen guys with Rokmen's which are nice. The mount I picked up at Autozone for $30.
I got the idea from Max's thread in the FAQ section:
http://www.jeepforum.com/forum/f12/t...cement-903109/
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 03-12-2012, 09:45 AM   #3
YJmaddness
Sweet ill check that out.
Here is a vid from a buddys iphone going down what destroyed me coming back up. Don't have much of the assent. I really need to upgrade my axles and get gears and lockers if I want to keep playing this way haha...
Unread 03-12-2012, 09:47 AM   #4
GOWAD
http://www.undercoverfab.com/transfe...bl-carbon.html if you have the money
http://www.undercoverfab.com/transfe...yj-carbon.html if you have the money and bl
or just hammer it back to place free
GOWAD is offline   Reply With Quote
Unread 03-22-2012, 11:58 AM   #5
YJmaddness
So 2 weeks later and lots of bicycle commuting I finally get a look at the jeep.
The whole trany is shifted to the driver side.
Photos drive line angle
Shift linkage sitting against tub
And mount bolt comming through the skid plate
Unread 03-22-2012, 11:59 AM   #6
YJmaddness
Unread 03-22-2012, 12:00 PM   #7
YJmaddness
Unread 03-22-2012, 12:13 PM   #8
Louie4
Injanir
Louie4's Avatar
That sucks big time.
Lou
Unread 03-22-2012, 12:57 PM   #9
jbolty
ISO 9001 Compliant
jbolty's Avatar
It's pretty common for the tranny mount to come apart and the driveline to shift. The OEM style mount, and most of the aftermarket ones, are just glued together rubber. I carry a spare.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 03-22-2012, 01:06 PM   #10
YJmaddness
Im just thinking get a new mount. Is there going to be more to it than that? You are gettin me worried....haha
Unread 03-22-2012, 01:12 PM   #11
Louie4
Injanir
Louie4's Avatar
That's all I would do is get a new mount. I would also inspect the engine mounts too.
Lou
Unread 03-22-2012, 02:04 PM   #12
YJmaddness
Looks like I may need motor mounts as well. Would Autozone cary such or will I need to order some?
Unread 03-22-2012, 02:13 PM   #13
sebastian22
wow, whatever you did shifted your entire drivetrain....a lot!
check out 4wd, 4wheelparts or quadratec, they often sell motor and tranny mounts together as a kit.
95 Black YJ
sebastian22 is offline   Reply With Quote
Unread 03-22-2012, 02:18 PM   #14
YJmaddness
I think they are all original with 200,000 miles on them and I just really bounced the crap out of it.
Unread 03-22-2012, 02:21 PM   #15
dillonjm
Blimps are terrible...
dillonjm's Avatar
If you have the extra cash now would be a good time to upgrade to some Brown Dog mounts. A lot nicer than stock. I went through a couple sets of stock style motor and transmission mounts before switching.
Offroading isn't easy on parts, might want to upgrade while you have it apart.
01 WJ Limited - 4.7L - Current build here
08 Dodge 2500 Laramie(DD/Tow Rig): Cummins 6.7L/G56 6spd, Deletes, Smarty, SBDD3250, 3.5" / 285 75/18 Toyo AT2s / B&W Gooseneck
05 Liberty Limited (Wife's): 3.7/Auto, OME + Clevis + Rear Iso's, JBA upper arms, 245 70/17 Duratracs w/stock 17" Limited wheels and 1.25" spacers.
dillonjm is offline   Reply With Quote
