Transmisson filter? - JeepForum.com
post #1 of 8 Old 09-18-2013, 07:01 PM Thread Starter
pbmustache
Transmisson filter?
Ok, is this a transmission filter that came standard on my 1993 jeep? Or did someone add it? The jeep starting leaking trans fluid when I crawled underneath is when I spotted this filter. It's on the front right of the jeep. That's why I think inline trans filter and not power steering filter.
pbmustache is offline
post #2 of 8 Old 09-19-2013, 07:07 AM
vadslram
Aftermarket.
The stock one is a pancake affair inside the pan.
vadslram is offline
post #3 of 8 Old 09-19-2013, 08:41 AM Thread Starter
pbmustache
I found one on carpartsdiscount.com for around $8. Should I replace it or remove it?? Does it even help with filtering the trans fluid?
post #4 of 8 Old 09-19-2013, 09:04 AM
jokerchief462
I'm sure it helps. Up to you. More important though stop the leak. And has the internal filter ever been replaced lately??
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 8 Old 09-19-2013, 09:17 AM Thread Starter
pbmustache
I've only had the jeep for so I don't know, however I have a feeling it has not been done in a while. It is definitely on my to do list.
post #6 of 8 Old 09-19-2013, 09:28 AM
jokerchief462
Yeah I would fix the leak probably the hose connections. If you want change the filter.
Sent from underneath my Jeep
post #7 of 8 Old 09-19-2013, 09:42 AM
jbolty
jbolty's Avatar
I added a filter for a few reasons: Filtering, an extra quart of fluid helps with cooling, the filter housing I got has a sender for a temp gauge.
jbolty is offline
post #8 of 8 Old 09-19-2013, 11:09 AM
jokerchief462
Jbokty that is great info. A lot of folks with autos need to look into the filter an external cooler and a temp gauge.
