Transmission Whine? - JeepForum.com
post #1 of 8 Old 12-30-2009, 03:26 PM Thread Starter
GA95YJ
Transmission Whine?
The jeep started to make a whining/screeching sound today. It's coming from the transmission because it only happens while it's in gear. The sound isn't constant, it comes and goes intermittently. Typically occurs in 1,2,3 gears. It's a stock AX-5 transmission. Any ideas?
99 GC, Yakima MegaWarrior, 245/75/16 BFG AT TA/KO, 2" BB
GA95YJ is offline
post #2 of 8 Old 12-30-2009, 09:22 PM
MJMPC
Did you check the oil level in the trans ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 8 Old 12-30-2009, 10:04 PM
yj98joe
throwout bearing?
yj98joe is offline
post #4 of 8 Old 12-30-2009, 10:06 PM Thread Starter
GA95YJ
honestly, i have no idea what a throwout bearing is
GA95YJ is offline
post #5 of 8 Old 12-30-2009, 11:45 PM
Clamwacker
Does the sound go away if you're moving with the clutch in, or does it change depending on how much throttle you're giving it? The throwout bearing is the part that helps the clutch separate from the flywheel, and the whine you describe indicates that the bearing could be going bad.
Also, does the sound change depending on which part of a given gear you're in? (ie high RPM vs low RPM) I'm not very knowledgeable on transmissions and clutches but this information will definitely help others to diagnose your problem.
Red Jeep Club #496
Clamwacker is offline
post #6 of 8 Old 12-31-2009, 10:37 AM Thread Starter
GA95YJ
the sound goes away with the clutch in. as far as how much throttle, it doesn't seem to matter. I'm not sure about low vs. high RPMs. i'll check later today and see. I do know that it didn't seem to make the sound when i let off the gas completely (engine braking).
GA95YJ is offline
post #7 of 8 Old 12-31-2009, 12:04 PM
ionakana
Grand Poobah
ionakana's Avatar
check your u-joints on the driveshaft.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #8 of 8 Old 12-31-2009, 12:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would start with a fluid change. Use 10W-30 motor oil. Yes, it IS the correct fluid. I would suspect that you have synchronizers on their way out.
Here is a pic of the throwout bearing, just for informational purposes.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Transmission whine? 93jeepsport TJ Wrangler Technical Forum 3 10-17-2007 10:35 AM
TJ Transmission whine Wild Bill TJ Wrangler Technical Forum 2 04-09-2007 10:33 AM
Transmission whine blazin YJ Wrangler Technical Forum 16 10-05-2006 06:30 AM
Auto Transmission Whine remedy 66 TJ Wrangler Technical Forum 7 02-21-2006 08:24 AM
Transmission Whine jo88gta YJ Wrangler Technical Forum 7 03-05-2004 04:21 PM
