Transmission Whine - JeepForum.com
post #1 of 8 Old 03-03-2004, 06:22 PM Thread Starter
jo88gta
Transmission Whine
My 92, 5sp has been making a whining noise for a few weeks. When accelerating in 1,2,3 and 5th gears it whines. Let off the gas or push in the clutch it goes away. 4th seems fine and at this time the tranny is my best guess. Can the transfer case be at fault? Any other ideas?
All fuids are new and full. If it is the trans, should I do an upgrade of any kind?
1992 Wrangler - 2.5, 5 Speed
190K and still going stong - most of the time!
jo88gta is offline
post #2 of 8 Old 03-03-2004, 08:10 PM
TonkaToy
I've got a 93 5spd with the same problem. Mine is most pronounced in 1st and 2nd gear at lower speads, and just barely on the gas. (it's probably louder with more gas, but I imagine the whine is drowned out by engine noise/vibrations.
I don't have an answer, but wanted to throw out there, you're not the only one. Anyone with idea's on this on??
TonkaToy is offline
post #3 of 8 Old 03-04-2004, 07:04 AM Thread Starter
jo88gta
How long have you had the problem? Has it gotten much worse since you first noticed it?
jo88gta is offline
post #4 of 8 Old 03-04-2004, 10:43 AM
CanukYJ
CanukYJ's Avatar
Probably needs a rebuild, mine used to do that, syncro's were fried too but that's a diff prob all together, I had them rebuild the tranny and get NEW BEARINGS in all gears. Those bearings wear over time ESPECIALLY if at some point you had water in the tranny. Might need a bearing kit installed, considering the labour and price involved IF this is the problem I would either: have the syncro's done at the same time, might as well while yer in there, OR buy a rebuilt tranny with a warranty from an online store (cheaper). But this is just worst case scenerio. Don't wanna be a doomsayer or anything.
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer?
1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....)
Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$.
CanukYJ is offline
post #5 of 8 Old 03-04-2004, 10:49 AM Thread Starter
jo88gta
What about picking one up from a junk yard? It there a stock upgrade if I'm looking at a used one? Thinking about selling the jeep at the end of summer.
THANKS!
jo88gta is offline
post #6 of 8 Old 03-04-2004, 10:56 AM
CanukYJ
CanukYJ's Avatar
A junkers one can go 50\50. You will probably find one that is fine, or you will find one that is COMPLETELY blown up, or maybe has the same issue. A junker is always a gamble really. If they offer some sort of gurantee then it might be worth it.
CanukYJ is offline
post #7 of 8 Old 03-05-2004, 05:15 PM
TonkaToy
I've got 93k miles on it now. Bought it with 87k and she's been whining as long as I've owned her. I don't think it's gotten any worse over time though. I have taken the tranny completely under water during my offroad excusions.
How much should I expect to pay for a bearing and syncro job? Am I better off getting a rebuilt tranny instead. What's the downside to just leaving it as is for now? Will I be stranded along the side of the road, or stuck in 2nd gear?
Thanks.
TonkaToy is offline
post #8 of 8 Old 03-05-2004, 05:21 PM
CanukYJ
CanukYJ's Avatar
Syncroís and bearings cost me approx 900$ Canadian all said and done. That was charges to my warranty though, and warranty charges (it was a used car warranty) tend to be a little less, kind of like contractor discount. So expect almost 1000$ at some places. What will happen? Itís a timebomb without a timer IF it is the bearings, could be 2 yrs, could be 2 miles and BANG chunks of tranny come apart, fly into other moving things, bang more chunks, those go into other moving things, bang bang bang, it tears itself apart. Goto the junkers, find a tranny thatís the same on a jeep, drain the fluid into a pan and make sure it has fluid and make sure the fluid did NOT have an water in it (let it separate in the pan). If there was fluid and no water, fluid doesnít smell burnt, push the shifter through all gears and then buy it for like 200$. Cheaper and a good solution if you plan on selling it anyways.
CanukYJ is offline
Transmission Whine? GA95YJ YJ Wrangler Technical Forum 7 12-31-2009 01:13 PM
Transmission whine? 93jeepsport TJ Wrangler Technical Forum 3 10-17-2007 11:35 AM
TJ Transmission whine Wild Bill TJ Wrangler Technical Forum 2 04-09-2007 11:33 AM
Transmission whine blazin YJ Wrangler Technical Forum 16 10-05-2006 07:30 AM
Auto Transmission Whine ArchAngel78 TJ Wrangler Technical Forum 4 07-08-2005 02:58 PM
