transmission or tcase issue - JeepForum.com
post #1 of 7 Old 07-30-2013, 03:28 PM Thread Starter
varent
I have an issue with my four wheel drive that started this past week. when i am in 4hi or 4low and let the clutch out all the way it grinds and no power to wheels but if i barely let it out and just want to creep along it is fine. also in 2 wheel drive it is 100% fine. Im thinking it is my transfer case but before i start pulling it i wanna get some second oppinions on it. thanks in advance.
varent is offline
post #2 of 7 Old 07-30-2013, 04:27 PM
jeff_in_rc
I would check to see if any of the bolts that hold the t-case shifter have come loose or fallen out first. Or it is out of adjustment. Check the simple stuff first in my book.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #3 of 7 Old 07-30-2013, 05:11 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Sounds like its half engaged. do what he said^^ my blazer does this cause i have to shift it through a hole in the floor by hand haha.
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #4 of 7 Old 07-31-2013, 12:21 PM
Rproject
1987 YJ Wrangler
X3 on Jeff's comment.
My t/c was slipping and it turned out that two of the three bolts that hold the shift lever to the tower were loose/missing. Sometimes it's the simple things that give us the most grief.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 7 Old 08-01-2013, 09:24 AM Thread Starter
varent
update: i checked the linkage and it all seems tight, but i think we are onto something. it seems my 4wd is getting stuck half way engaged or something. my 4wd light will be on while im in 2wd and if i slam the shifter up and down it will eventually fully disengage. should i worry about driving it in 2wd as it is right now or should i park it for now and walk to work? what would be causing it to not really disengage all the way.
varent is offline
post #6 of 7 Old 08-01-2013, 09:27 AM
Rproject
1987 YJ Wrangler
Have you checked your fluid level?
Does your rig have any lift on it? The shifter could be hitting the cutout in the tub and not allowing it to fully engage/disengage.
1996 White ZJ
Rproject is offline
post #7 of 7 Old 08-01-2013, 10:10 AM Thread Starter
varent
i will check my fluid level. i dont see why it would be all the sudden hitting the tub since its been lifted for the 4 years ive had it and it has never had this problem. unless i have some new sag going on.
varent is offline
