Transmission and T-case Help - JeepForum.com
post #1 of 7 Old 03-10-2010, 05:25 PM Thread Starter
TrueYJfan
I have an '89 YJ 4.2L with the factory BA10/5 trans. and I believe the NP231 t-case. I was wondering if anyone could tell me how to tell if it is the NP231 (I already looked for the tag but it is long gone) and also if I swap out the BA10/5 will the AX-15 bolt in or will I need a different t-case. Thanks
TrueYJfan is offline
post #2 of 7 Old 03-10-2010, 05:44 PM
markr1001
1987 YJ Wrangler
ba10 has a 21 spline output and the ax15 has a 23 spline output, so you either need a input shaft or a whole new case...
markr1001 is offline
post #3 of 7 Old 03-10-2010, 07:17 PM Thread Starter
TrueYJfan
Thanks, would I be able to take the input shaft out of the BA10 and put it in the AX15 or not?
post #4 of 7 Old 03-10-2010, 07:35 PM
RikRotorhead
No. It's the output shaft of the transmission that is different.
In the t-case planetary gears there is an input gear that can be changed. It's $192 from advance adapters, plus shipping and tax.
It's best to get the NP231 with the AX15 trans. Everything will bolt up and you only need to change the pilot bearing on the flywheel, $7 at AutoZone.
The BA10/5 trans only had the NP207 and NP231/amc t-cases, both 21 spline. The AX15 uses the NP231/J, 23 spline.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #5 of 7 Old 03-10-2010, 07:59 PM Thread Starter
TrueYJfan
Thanks how can you tell the difference between the NP231 amc and the 231j?
post #6 of 7 Old 03-10-2010, 08:10 PM
monkeyhouse
so if you get an ax-15 and the T/C the t/c will bolt up ok? That's cool.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #7 of 7 Old 03-11-2010, 07:31 PM
RikRotorhead
There is a round tag on the back of the t-case that is red and silver that has the identification numbers on it.
If the tag is gone, look at the transmission. If the transmission has a seam running the length of it along the bottom, that is a BA10/5. The BA10/5 is a 21 spline whether it's a 231amc or a 207.
If there is no seam, it's an AX15 and it's a 23 spline which is the 231/J.
Yes. If you buy the tc with the trans (ax15) it will bolt up. BUT, the pilot bearing is a different size in the flywheel. You will have to pop that one out and put the one in for the AX15. They are available at any good auto parts store for under $10.
RJC#512
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 04:10 PM
Broke my Transmission case. VS Bullet JK Wrangler Technical Forum 2 08-27-2007 11:43 PM
New transmission and transfer case mjm TJ Wrangler Technical Forum 5 11-10-2006 06:10 PM
Your Favorite Transmission and T-Case Oil? skipjack YJ Wrangler Technical Forum 1 04-08-2006 06:32 PM
