Transmission Synchronizer? - JeepForum.com
post #1 of 3 Old 10-03-2002, 07:44 PM Thread Starter
WranglerYJ94
It's been getting harder to shift gears lately...and if I shift real fast it grinds. I have found the only way to not have the gears grind when i shift is to wait a few seconds then shift. It doesnt do it in all the gears, mainly when i shift into first when a light turns green and shifting from 3 ---> 4. Also, I sometimes can't downshift to 2nd, it will just grind. A local truck accessory shop told me it was my transmission synchronizer (spelling?) that needed replacing. How much of a job is this? Is it an afternoon driveway project, 30min project, or a $$$ job? Thanks for the help, yall are awesome.
'94 YJ
2" BDS
31s
Flowmaster exhaust
Lights
Lotsa 'stuff'
WranglerYJ94 is offline
post #2 of 3 Old 10-03-2002, 07:55 PM
tophillrod
tophillrod's Avatar
This would be a $$$ job. I have the same problem, but only in 2nd & third. I have not looked for prices yet, but I have heard that it is somewhere in the vicinity of .....might as well just get a re-built one instead.... I am going to live w/ mine for now until it gets really bad, then I will deal w/ it (most likely buy a re-built one).
'92 YJ 4.0 HO
2" SL 2" BL 33" BFG AT's (for now)
RE quick disco's
Warn tire rack
Dana44 rear w/ Track lock
4:10 gears
135k and running strong...
tophillrod is offline
post #3 of 3 Old 10-03-2002, 08:57 PM
RideRed04
RideRed04's Avatar
Yup, mines going out too, and the throw out bearing is getting bad too, so when it all goes, its time for an nv4500 and a 350...
2000 WJ Limited 4.7 QD
RideRed04 is offline
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 04:10 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 07:43 PM
bad transmission? OutDoorDawg TJ Wrangler Technical Forum 12 07-08-2007 04:34 PM
synchronizer? yooperlou YJ Wrangler Technical Forum 4 07-24-2006 07:12 PM
