Transmission slipping or popping in 4th/5th gear..? - JeepForum.com
post #1 of 2 Old 03-13-2011, 04:21 PM Thread Starter
sarinalove
Hello everyone! We bought our 92 Wrangler this past May and shortly after started having an issue with the transmission. When in 4th and/or 5th gear it occasionally will slip or pop out of gear- it's sort of like when you run out of gas, all of a sudden the car just isn't engaging- I'm not any good with technical lingo so that's probably the best I can explain it. It typically does it shortly after we first start driving, and it's normally just at higher speeds (4th/5th gr), but it recently started doing it in 2nd/3rd gear. What do you think this could be? It is drivable but I think the problem might be getting worse- it seems like it mostly does it while the jeep is still getting warmed up or something. I've had one person say it may need a new trans and someone else say a new clutch? Please and thank you for any insight you may have!
sarinalove is offline
post #2 of 2 Old 03-13-2011, 08:45 PM
moonshinefuel
Read this, can't tell if you have a body lift, suspension lift, or anything from your profile, doubt its the clutch. http://www.jeepforum.com/forum/f12/transmission-slipping-out-gear-after-lift-9426/
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
gears , jeep , slipping , transmission
jeep 1998 transmission slipping from 1-2 gear (automatic) ReD-RuM TJ Wrangler Technical Forum 3 10-25-2009 03:14 PM
popping or slipping out of 5th gear at 160K jeepcrd2010 TJ Wrangler Technical Forum 2 12-08-2007 08:46 PM
Transmission slipping out of gear after lift mikeyjph YJ Wrangler Technical Forum 7 11-18-2007 02:05 PM
NP 231 popping,slipping? SHSU Tadpole YJ Wrangler Technical Forum 5 10-10-2007 08:16 PM
Transmission just replaced...now popping out of first gear. HELP! Ford4Now TJ Wrangler Technical Forum 9 04-06-2007 08:21 PM
