Transmission Related (interior leak) - JeepForum.com
post #1 of 3 Old 10-24-2001, 01:58 PM Thread Starter
bigjeep39
bigjeep39's Avatar
I took the carpet out of my jeep because the carpet was rotted out by the stick shift. Then when i looked i noticed the transmission hump panel is not fully bolted to the floor board so there is some air getting in, when i went through water, even when it rains it leaks into the car, i wanted to get ne carpet, BUT i dunno how to fix this, do i have shop do it or do i silicone it myself, PLEASE HELP, i have the carpeting and i want to put the new stuff in but i will have to wait?
Thanks
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 3 Old 10-24-2001, 04:53 PM
powjunkie
Sometimes the plate under the shift boot becomes bent when it's removed for clutch maintenance. The first thing is to make sure that it's straight enough to make a good seal. Another problem is that some of the sheet metal screws could be stripped out, so you might have to go with a bigger size. I think that silicone would be fine for sealing it back up once everything is checked out. There is a seal that is supposed to be there, maybe it's missing or just not working like it should.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #3 of 3 Old 10-24-2001, 05:49 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Hey thanks, sound like i am boing to be busy tonight, i just got done removing the nerf bars for rocker panels now i am going to make my jeep SUBMERGEABLE, hell yes, thanks a bunch.
1998 TJ
Transmission related issue RogueStatus JK Wrangler Technical Forum 6 02-16-2010 03:13 PM
Exhaust leak. Any related issues? YJake YJ Wrangler Technical Forum 0 08-27-2009 06:44 PM
Replaced starter but still won't turn over...leak from b/t tranny and TC...related? GDM97TJ TJ Wrangler Technical Forum 34 08-16-2008 08:45 PM
4WD vac leak? engine related? YJames90 YJ Wrangler Technical Forum 3 07-19-2008 10:40 AM
Some vent that might be related to rear main seal leak? TheMightyGoat TJ Wrangler Technical Forum 11 05-13-2008 07:57 PM
