-   -   Transmission Related (interior leak) (http://www.jeepforum.com/forum/f12/transmission-related-interior-leak-7300/)
bigjeep39 10-24-2001 01:58 PM
I took the carpet out of my jeep because the carpet was rotted out by the stick shift. Then when i looked i noticed the transmission hump panel is not fully bolted to the floor board so there is some air getting in, when i went through water, even when it rains it leaks into the car, i wanted to get ne carpet, BUT i dunno how to fix this, do i have shop do it or do i silicone it myself, PLEASE HELP, i have the carpeting and i want to put the new stuff in but i will have to wait?
Thanks :D
powjunkie 10-24-2001 04:53 PM
Sometimes the plate under the shift boot becomes bent when it's removed for clutch maintenance. The first thing is to make sure that it's straight enough to make a good seal. Another problem is that some of the sheet metal screws could be stripped out, so you might have to go with a bigger size. I think that silicone would be fine for sealing it back up once everything is checked out. There is a seal that is supposed to be there, maybe it's missing or just not working like it should.
bigjeep39 10-24-2001 05:49 PM
Hey thanks, sound like i am boing to be busy tonight, i just got done removing the nerf bars for rocker panels now i am going to make my jeep SUBMERGEABLE, hell yes, thanks a bunch.
The time now is 09:38 PM.
