Transmission question - JeepForum.com
post #1 of 30 Old 12-05-2012, 04:36 PM Thread Starter
flcracker
I see a Tranny for a TJ 4 cylinder Jeep listed on Craigslist for $450, not sure what all comes with it or how many miles on it.... Will it fit into my '92 to replace the one in it with worn synchros?? If its not a straight bolt-in replacement, what would I have to do to use it??
EDIT: its out of a 2002
flcracker is offline
post #2 of 30 Old 12-05-2012, 05:19 PM
Opihi59
from here it gets rough
Opihi59's Avatar
It is not the same, but you should consider it to be an upgrade. This version AX5 will be external clutch slave style, with a long snout input bearing retainer. If you are getting the bellhousing with this tranny, it will be good. Swap out the entire thing, and get a new clutch hydraulic system master/slave/hose and bolt it all up. If you aren't getting the bellhousing, you can put your old style flat faced input bearing retainer on it and retain your cursed internal slave but why someone would do this I can't imagine.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 30 Old 12-05-2012, 06:30 PM Thread Starter
flcracker
Sent an e-mail asking what it came with, bellhousing, clutch parts, etc... How many miles?? Waiting for reply.
Would this bolt right up to my existing transfer case also?? If its the same ax5, it should right??
post #4 of 30 Old 12-05-2012, 07:41 PM
Opihi59
Opihi59's Avatar
Yes, it should.
Opihi59 is offline
post #5 of 30 Old 12-06-2012, 02:38 PM
Opihi59
Opihi59's Avatar
The only clutch part you'd really care to have would be the clutch fork. I didn't mention that earlier. Any clutch parts such as clutch, pressure plate, throwout bearing etc would all be worn parts and shouldn't be used. It is not very likely though that the clutch fork would come with this, but they are cheap and are carried at parts stores, and online places like quadratec, etc. They are the same for the AX15 as well as the AX5 (same part number). Let us know what response you get from the Craigslist seller, see if he'll send you photos you can link up here. Pictures are worth.......well, they're worth a lot.
Opihi59 is offline
post #6 of 30 Old 12-06-2012, 05:32 PM Thread Starter
flcracker
Wasn't thinking about the wear parts as much as any hydraulics that might come with it.... and no reply yet....
post #7 of 30 Old 12-06-2012, 09:32 PM
Opihi59
Opihi59's Avatar
Isn't it amazing that people put stuff up on CL, and take days to get back to a response to their ad, or not at all. Or don't pull their ad once it sells.......
Opihi59 is offline
post #8 of 30 Old 12-07-2012, 05:46 AM Thread Starter
flcracker
Another e-mail sent... maybe I can get an answer this time??
post #9 of 30 Old 12-17-2012, 01:03 PM Thread Starter
flcracker
Almost forgot about this thread and started another.... anyway, I found a new ad for the 02 tranny with phone number but also found this AX15 with transfer case on craigslist from 1990 (read internal slave) wrangler for $300 here:
http://fortmyers.craigslist.org/lee/pts/3483042806.html
Here is the ad for the 02 AX5 freshly rebuilt with bellhousing and slave for $450 here:
http://fortmyers.craigslist.org/lee/pts/3457700389.html
I know I have to do some engineering with the ax15 and I've never dove into the guts of a transmission or transfer case before and the ax5 will require some changes in the clutch system....
not a hardcore wheeler and will likely spend most of its time on trails or maybe a little mud if we decide to get the right tires for it.
Suggestions??
post #10 of 30 Old 12-17-2012, 01:38 PM
Opihi59
Opihi59's Avatar
Remember the AX15 won't be a direct bolt in. You will need to get a 4 cyl Dodge Dakota bellhousing that came with an AX 15 to be able to bolt this up to your 2.5, and it may be difficult to find that bellhousing as there is no market glut on that particular part. Likely will be easier for you to work with the AX 5 even though it is a weaker tranny (but it's what you're running right now anyway) than to come up with a rare/vintage bellhousing so you can use the AX15, and you will have to come up with some modifications to your T case so it would bolt up with your "new" AX15 setup.
Opihi59 is offline
post #11 of 30 Old 12-17-2012, 03:43 PM Thread Starter
flcracker
What kind of master/hyd line/slave cylinder would I want to go with?? If I read it right there are different parts listed for the '02 and late YJ with slave....
I knew I would need a lot more than just a Dakota bellhousing for the AX15 (although I did locate one not that far away on car-parts.com) I really don't want to dive into the Transfer Case either.
post #12 of 30 Old 12-17-2012, 04:00 PM
Opihi59
Opihi59's Avatar
Were you to go with the 2002 AX5, you would get a clutch assembly for a 94/5 Jeep. You would get a clutch master/hose/slave for a 94/5 Jeep, and you'd stick with your year flywheel for your Jeep. The TJ clutch master is a lot longer, it also has a clutch safety switch built into it so it is not compatible with your year Jeep.
This would be all predicated on getting the 2002 bellhousing as well and making the conversion to an external slave. Were you to just get the trans, and bolt it to your existing internal slave bellhousing, then you would stick with all components for your year Jeep.
Opihi59 is offline
post #13 of 30 Old 12-17-2012, 04:51 PM Thread Starter
flcracker
Talked to the guy on the phone and he bought it for his Jeep not knowing there was a difference between the 6 cylinder trans and the 4 banger.... it was rebuilt and comes with bellousing and the slave cylinder...
Right now, its just sitting there and he can't use it. Apparently, there isn't that much of a market for these down here
post #14 of 30 Old 12-17-2012, 04:55 PM
Opihi59
Opihi59's Avatar
Buy it. Install it, smile and drink beer.
Opihi59 is offline
post #15 of 30 Old 12-17-2012, 05:02 PM Thread Starter
flcracker
recommendations on a clutch?? I need to keep cost down on my teacher salary....
