transmission problem with 1993 yj - JeepForum.com
post #1 of 14 Old 01-10-2014, 07:09 PM Thread Starter
RCwheelin
Hi guys, so long story short, my jeep was at a mechanic for a few days for a transmission leak. This sucks because this tranny is only 6 months old! Anyways when I got it back it developed a god-awful chipmunk squeak that is coming from my transmission(not my transfer case as I say in the video... So any help on identifying the noise would be greatly appreciated!
93' YJ
RCwheelin is offline
post #2 of 14 Old 01-10-2014, 07:37 PM
JBTJ
What part was leaking? Maybe that HUGH t-case drop has something to do with it.
JBTJ is offline
post #3 of 14 Old 01-10-2014, 07:43 PM Thread Starter
RCwheelin
Yeah it's not as big as it looks in the video and the part where the transmission housing meets the t-case... There is a hairline crack in the tranny housing so Mr.mechanic said it needs to be replaced
93' YJ
post #4 of 14 Old 01-10-2014, 08:01 PM
JBTJ
There is or was a crack? Maybe he didn't get a seal put back in properly. Can you take it back to him and say hey your repair is leaking?
JBTJ is offline
post #5 of 14 Old 01-11-2014, 01:28 AM Thread Starter
RCwheelin
There is a crack right now. Only problem is the guy who did the tranny is a 2 and a half hour round trip away and I don't want to spend money on something that doesn't need to be fixed (ex. Whole transmission housing) for the mean time I can deal with a small leak. What I can't deal with is the loud squeaking noise that current mehanic caused when trying to repair said leak. So I want to fix it myself or know what it is so I don't get screwed! And thanks for responding this is my first thread on jeep forum and it's good that theres guys that will help out with questions like this
93' YJ
post #6 of 14 Old 01-11-2014, 06:49 AM
fishadventure
exhaust or tranny mount movement? It doesn't sound internal, especially the way it sounded when you shut it down.
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
post #7 of 14 Old 01-11-2014, 07:11 AM
kloppk
It's not the tcase or tranny. Sounds like a loose exhaust system or the exhaust system rubbing somewhere.
Just go under the jeep and start to wiggle the exhaust and find the squeak.
FYI - Nothing is moving in the tcase with the tranny in neutral so it's definitely not that.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #8 of 14 Old 01-11-2014, 08:33 AM
JBTJ
May want to get under the JEEP and spray small areas with WD-40 to find the noise. Then that will help determine how to fix it for good. Like you, I hate squeaks and will do anything to get rid of them. Good Luck finding it.
JBTJ is offline
post #9 of 14 Old 01-11-2014, 08:42 AM
Jeepsr4me
Sounds like the heat shield rubbing on something.
Jeepsr4me is offline
post #10 of 14 Old 01-11-2014, 11:22 AM Thread Starter
RCwheelin
Alright I'll try my best, thanks
93' YJ
post #11 of 14 Old 01-11-2014, 11:44 AM
JBTJ
Please keep us informed with what you find.
JBTJ is offline
post #12 of 14 Old 01-11-2014, 11:48 AM
JBTJ
Now that I have a speaker hooked up so I can hear the noise. Sounds like the shifter hitting something, Duh!. Should be real easy to find since it does it with the engine off. Just get a buddy to sit in the JEEP and have him keep moving the shifter around to make the noise and you get under there and pinpoint where it's coming from. Don't forget the WD-40.
JBTJ is offline
post #13 of 14 Old 01-12-2014, 04:40 PM Thread Starter
RCwheelin
Found it! Not even the transmission it was a broken mount for my exhaust pipe... The bushing for the mount dry rotted so I zip-tied it for a quick fix until I get a new mount. Thanks guys i really appreciate the help!
93' YJ
post #14 of 14 Old 01-12-2014, 05:02 PM
JBTJ
Glad you found it, Good Job.
JBTJ is offline
jeep , problem , transmission , YJ
