transmission pan gasket - JeepForum.com
post #1 of 5 Old 07-29-2010, 08:15 AM Thread Starter
toothey007
my transmission pan gasket is hosed. took it off last year, cleaned in up, and used a new gasket but no gasket maker or anything. its now starting to fail again. i understand about being too tight and warped the pan and all that. do you think that a lube locker gasket plus gasket maker is going to make it last longer than a year?
if i dont have a torque wrench is there any way to determine how tight is too tight for the pan bolts?
one more thing, i've seen a lot of different theories about how to use gasket maker. is one big bead going to work, that will theoretically squeeze out flat when you put the pan on? i've also seen the guys on trucks use a thin bead all along the mating surface , spread out by hand(finger).
toothey007 is offline
post #2 of 5 Old 07-29-2010, 10:26 AM
ctm
install the lube locker dry - no gasket maker. if you have the original steel pan the trick is to lay it upside down on a flat surface and using a flat brass punch and/or a thin block of wood, even out the entire sealing surface of the pan and make it perfectly flat, especially the holes where the bolts go through. Then install the pan following the lube locker instructions to the letter, using the correct torque and sequence. do not overtighten and distort the pan.
ctm is offline
post #3 of 5 Old 07-29-2010, 11:28 AM
pasinbuy
As a rule to torque without a torque wrench on pans and valve covers. Grab the top of the wrachet wrench where you turn it forward and reverse and wrist tighten. Do not tighten them by the handle.
pasinbuy is offline
post #4 of 5 Old 07-29-2010, 11:40 AM Thread Starter
toothey007
hm, ok, why no gasket maker?
post #5 of 5 Old 07-29-2010, 11:52 AM
jbolty
jbolty's Avatar
If you have a good sealing surface there is no need for rtv or anything else. But a little permatex aviation cement is not a bad thing to hold the gasket in place for the installation.
If you don't have a torque wrench, get one. Or at least borrow one long enough to get a feel for how 15 ft lbs feels. When you measure that much torque you will be surprised at how little it is and realize that doing it by hand you were probably going 2-3 times more than that; which is the source of all the stripped or broken bolts and dimpled and leaking pans.
jbolty is offline
Changing transmission pan gasket Cards89YJ YJ Wrangler Technical Forum 3 05-20-2010 09:34 PM
need to replace transmission pan gasket speepdaedeesi YJ Wrangler Technical Forum 2 03-26-2009 04:57 AM
AX5 Transmission Gasket Question amtgoodman YJ Wrangler Technical Forum 1 08-03-2007 11:24 PM
RTV Gasket and Transmission gasket am3rican TJ Wrangler Technical Forum 3 07-19-2007 07:54 PM
Transmission Gasket question... ZWhitt TJ Wrangler Technical Forum 6 09-01-2005 02:38 AM
