Transmission mount replacement help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Transmission mount replacement help
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-28-2010, 10:58 AM   #1
ZeroGravity
I ordered a new transmission mount because I've been having problems with my transmission moving around and clunking on acceleration from time to time.
Mean Max made a great write up with pics:
http://www.jeepforum.com/forum/f12/t...cement-903109/
However I was under my YJ and it looks like my transmission mount is farther back than What'sWrong's Jeep. If you follow the pictures in that thread, mine mounts up inside that square cut out behind where his mounts.
I have the same transmission mount they used in the thread. Is this normal and am I going to be able to use the transmission mount?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline   Reply With Quote
Unread 01-28-2010, 11:04 AM   #2
Why J?
I think What'sWrong's Jeep is a 4cyl. the 6 mounts further back. Also make sure you have the torque arm mount as well.
New Project "Pissed Wife"
http://www.jeepforum.com/forum/f12/project-pissed-wife-747535/
Why J? is offline   Reply With Quote
Unread 01-28-2010, 11:13 AM   #3
moonshinefuel
Exactly, the 4 cylinder mounts in the holes closer to the front of the jeep in the skid plate, the six cylinder uses the holes closer to the rear of the jeep. The skid plate was built for both 4 and 6 cylinders, depending on which transmission, ax5 or ax15 will determine which holes the mounting bolts will drop through as the the torque arm brackets are different for each application.
AX5/NV3550 Conversion Thread. http://www.jeepforum.com/forum/f12/n...irrels-752742/
Bow Hunting www.bowsite.com
moonshinefuel is offline   Reply With Quote
Unread 01-28-2010, 11:19 AM   #4
moonshinefuel
And yes you will be able to use the transmission mount, it will work, it is normal.
Unread 01-28-2010, 03:25 PM   #5
ZeroGravity
Ok, thanks for the help.
I overlooked the torque arm mounts. Is it important to replace these kind of things together?
91 YJ
98 XJ
2 door love
Unread 01-28-2010, 03:35 PM   #6
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually, What'sWrong's Jeep is a 4.0L, but it's an automatic. That just makes the bracket a little different. The tranny mount should be the same for all 4 & 6 cylinder, manual & auto models, with the bracket being different to accomodate the different needs.
Yes, replace the isolator (torque arm) bushings if you can get them before you start the job. However, they can be replaced later without dropping the skid plate.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 01-28-2010, 08:12 PM   #7
idaholtby
idaholtby's Avatar
Here is an illustration that should help...
idaholtby is offline   Reply With Quote
Unread 01-29-2010, 05:33 AM   #8
ZeroGravity
I just ordered a torque arm bushing set as well. Thanks for the help and the pictures you guys
91 YJ
98 XJ
2 door love
Unread 01-29-2010, 06:21 AM   #9
Why J?
While we are on the subject here. I have the torque arm bushings but the isolator stub and all the other bolts and washers are long since gone. Anyone know where I can pick one of these up?
http://www.jeepforum.com/forum/showthread.php?t=747535
Unread 01-29-2010, 08:33 AM   #10
Mean Max
Don't poke the bear
Mean Max's Avatar
Transmission Mounting Stabilizer Stud*5358879 by the Jeep Specialists | Morris 4x4 Center
Max
Unread 05-04-2010, 03:23 PM   #11
JOExFROMxNY
JOExFROMxNY's Avatar
Will this part work on an "88 YJ, automatic, with the 4.2 ?
JOExFROMxNY is offline   Reply With Quote
