Transmission Mount Replacement - JeepForum.com
post #1 of 98 Old 11-15-2009, 11:31 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Fellow JF member WhatsWrong needed his transmission mount replaced, so when he came over today to replace it I took a few pics along the way.
It's a fairly easy, straight-forward repair that can be done pretty easily & quickly.
First we got a new polyurethane mount.
The we removed the 2 transmission mount nuts & the nut from the torque arm stud.
We jacked up on the transmission pan enough to lift the weight off of the skid plate & placed a jackstand under the output shaft housing to hold everything up.
Here you can see the old rubber mount that uses 2 studs with nuts on them to attach to the skid plate.
The old mount wasn't broken, but due to a leaking automatic transmission pan it had become soft and collapsed, allowing the T-case to contact the skid plate.
The 2 nuts & bolts the held the OE rubber mount to the bracket on the transfer case were reused, and here you can see how much "taller" the new polyurethane mount is.
We reinstalled the skid plate and the torque arm stud nut. Notice how the new mount uses bolts through the skid plate, as opposed to the OE studs & nuts.
This makes for a lot "cleaner" skid plate with at least 2 fewer things to hang up on stuff!
Also, notice how much clearance there is between the skid plate & transfer case!
If yours is touching the skid plate or within a 1/2" or so of touching it, you should consider this repair!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #2 of 98 Old 11-15-2009, 11:56 PM
SDGBASSE
That's a great one, I mean it's not complicated at all but it should give the extra push for those out there afraid of messing up everything, BRAVO Max. BTW you lucky guy, you got no rust on your skid plate bolts....
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #3 of 98 Old 11-16-2009, 12:01 AM
Renegade88
I put the same mount in 2 months ago, lovin' it.
2006 LJ
PanhandlePierFishing.com
Renegade88 is online now
post #4 of 98 Old 11-16-2009, 12:03 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually, it's not my Jeep. The owner is a fellow JF member & friend (link to his profile in OP) and his Jeep is in near perfect condition! It's one of the cleanest YJs I've seen in a long time!
Surprisingly though, the skid plate bolts in mine & my wife's YJs are in good shape too!
Max
Mean Max is offline
post #5 of 98 Old 11-16-2009, 01:27 AM
jerseyrider1119
man i need to find some people in my area to get or offer help... flordia is looking mighty good in those pics.. jersey is pretty unpleasing right now
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline
post #6 of 98 Old 11-16-2009, 09:53 AM
timatoe
timatoe's Avatar
Max
I've drug mine over all kinds of stuff and the bolts are in perfect condition too.
Quite a while ago someone was having troubles finding that mount and when I told them it was the same as a Chevy mount they didn't believe me..... I'm saving this.....
[/CENTER]
timatoe is offline
post #7 of 98 Old 11-16-2009, 10:12 AM
RebuildRookie
Thanks for the pics Max, I go the same mount from Morris week before last because of you. I have the new muffler and insulator bolt also. Going in this week to change it all out.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #8 of 98 Old 11-16-2009, 04:44 PM
DirtyJeepBoy
Woop woop, that was a good day! Awesome guide Max ! Thanks for the compliment on the no rust on my skidplate SGD.
edit: Good pictures
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
My Build:
BDS/BTF/MCE
DirtyJeepBoy is offline
post #9 of 98 Old 11-16-2009, 07:23 PM
bpr
Did your friend buy mount at a local parts store or order it? How much $ ?
Thx
bpr is offline
post #10 of 98 Old 11-16-2009, 07:29 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thx
Funny story.
Actually I bought it a while back at an AutoZone Parts store for about $22 or so. I had planned on putting it in my '91 YJ while I was rebuilding my AX-15, but I misplaced it.
My old rubber one wasn't too bad so I left it in. A couple of weeks ago I stumbled across this new one, so I used it in his '93 and he is going to get me another one later on.
Max
Mean Max is offline
post #11 of 98 Old 11-16-2009, 08:09 PM
bpr
You misplace stuff too? Sounds like me man !
bpr is offline
post #12 of 98 Old 11-16-2009, 09:00 PM
bryris
So you have to remove the cross member?
I live in Lakeland, FL - maybe I could come to Stuart for some guidance on doing mine.
1995 YJ Sahara
bryris is offline
post #13 of 98 Old 11-16-2009, 09:16 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
If you mean the skid plate, yes it must be removed.
Max
Mean Max is offline
post #14 of 98 Old 11-17-2009, 07:27 PM
DirtyJeepBoy
My dad said he is ordering it soon so I will keep you updated.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
My Build:
BDS/BTF/MCE
post #15 of 98 Old 11-17-2009, 07:36 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
No worries, no hurries!
Max
Mean Max is offline
Transmission mount replacement help ZeroGravity YJ Wrangler Technical Forum 10 05-04-2010 03:23 PM
Transmission mount replacement without dropping the skid? JasonJW TJ Wrangler Technical Forum 3 07-29-2009 10:03 PM
Transmission mount 05RedRME TJ Wrangler Technical Forum 17 05-26-2009 07:39 PM
Automatic Transmission Mount Replacement 94YJ H.O. YJ Wrangler Technical Forum 8 01-10-2006 01:26 PM
transmission mount help?? dompaz YJ Wrangler Technical Forum 1 11-21-2005 04:09 AM
