Transmission Mount Bracket - Page 2 - JeepForum.com
post #16 of 18 Old 02-17-2014, 02:56 PM
dmoneyjr
This is for a 4.2 with 5 speed manual. Ouch! This bracket also holds the catalytic convertor. Without it the cat bangs on the cross member and transmission. I replaced motor, trans, ball joints, checked calipers nothing stopped the banging. Went to a muffler shop "rigged" some mounts, no banging on medium bumps. Still banging on bad potholes and such. There might still be a bigger problem. 1st attached image.
http://www.factorychryslerparts.com/...ssembly=621618
Also the bracket for the CAT is impossible to find. Item 16 in the 2nd attached image
http://www.factorychryslerparts.com/...driveLine=7417
dmoneyjr is offline
post #17 of 18 Old 02-17-2014, 02:58 PM
dmoneyjr
I made a mistake! It's actually item 11 on the diagram that mounts the CAT to the torque arm item 10.
dmoneyjr is offline
post #18 of 18 Old 08-11-2014, 01:55 PM
NeverAgain-Two
The JeepForum answers my questions again--priceless!! And thank you.
NeverAgain-Two is offline
Where did you mount your CB antenna bracket? Brandon97TJ TJ Wrangler Technical Forum 15 11-13-2008 06:47 PM
Engine mount bracket Wshift YJ Wrangler Technical Forum 7 06-05-2007 08:53 PM
Tranny Mount Bracket phil92YJ YJ Wrangler Technical Forum 1 09-04-2005 05:58 PM
Which Bracket Mount is this? wvspecialkvw TJ Wrangler Technical Forum 1 04-11-2004 11:10 PM
Antenna Mount Bracket??? cmerz37 TJ Wrangler Technical Forum 5 09-03-2002 12:49 PM
