transmission issues - JeepForum.com
post #1 of 3 Old 10-14-2009, 09:17 AM Thread Starter
92renegade
transmission issues
I'm new to the jeep world. I purchased my jeep 1 month ago. The PO stated the trans needed to be replaced. He couldn't tell me exactly why though.I have had a few issues with my transmision. I have a 4.0 with a 5 speed trans. I know it isn't the pueguo trans. The issue I have is sometimes it won't shift into 2nd gear. The other issue is sometime it grinds shifting into 4th gear on up shift or downshift. It seem the 4th gear grind is worst on downshift. The 2nd gear doesn't grind it just wont go in, I will have to shift to 3rd. It seems to shift into 2nd after it warms up. I have checked and drained the fluid. It was not low. The jeep does have 212000 on it. The clutch seems fine. I have had it flushed and refilled and bleed. Maybe it is time for a trans rebuild?
Frank
92renegade is offline
post #2 of 3 Old 10-14-2009, 10:16 AM
CreepyCrawler95
check the synchros and your throwout bearing. uve most likely have an ax15 if its behind the 4.0. my ax5 behind my 4banger did the exact same thing. 2nd gear lips, ive lost 5th and 4th was about to go, the throwout is bad synchros are bad and it grinds in every gear so its done for. im swapping in an ax15. id check those 2 things first though. and check your fluid level before all of it just to be sure
CreepyCrawler95 is offline
post #3 of 3 Old 10-14-2009, 10:28 AM Thread Starter
92renegade
I have checked drained and refill fluids. That was the first thing I had done. 2nd gear doesn't slip. When you try to shift to 2nd it feels like there is something in the way no matter how hard you pull. But when ot warms up it is fine. The 4th gear shift sometimes it shifts smooth and sometimes it shifts hard with no grinding. Sometimes if I rev the motor alittle it shifts with out grinding.I would think if the clutch is an issue this would be in all gears.
AX-5 Transmission Issues WranglerYJ94 YJ Wrangler Technical Forum 16 11-29-2012 03:49 PM
transmission issues jeepwrnglr92 YJ Wrangler Technical Forum 11 07-07-2009 05:42 AM
Transmission Issues... AX5 paccepounder YJ Wrangler Technical Forum 2 02-08-2009 06:08 PM
transmission issues mtn_wrangler YJ Wrangler Technical Forum 8 06-30-2008 12:38 AM
Transmission issues.... mikecassidy1975 TJ Wrangler Technical Forum 3 11-05-2007 12:24 PM
