Quantcast transmission issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > transmission issues
Old 06-17-2008, 05:48 PM   #1
mtn_wrangler
transmission issues
ok so my stock puegout transmission's first gear went kaputz so i went and picked up another puegout to swap in and i have it in and all ready to go but then i went to go through the gears to make sure it shifts fine and at first it would only go 1-4 but no 5th or reverse and then nothing at all just stops moving. turns out the shifter got stuck in reverse then it was almost like i put it in reverse pulled the shifter out and slide it back into neutral so the tranny was locked up. so i fixed it and same thing only goes 1-4 then after a bit it gets stuck in the same spot. im completely baffled as to why its doing this as it makes no sense to me. i want to stick to this tranny just because i have it. so any help would be nice
thanks in advanced
joe
mtn_wrangler is offline   Reply With Quote
Old 06-17-2008, 06:12 PM   #2
mtn_wrangler
1234567890
Old 06-17-2008, 06:50 PM   #3
mtn_wrangler
someone has got to have suggestions
Old 06-17-2008, 07:13 PM   #4
ctm
I think we are all trying to figure out if you are the first person to ever swap in a Peugeot for a Peugeot.
Seriously, though , now you have 2 bad trannys, go out and find an ax-5/15 to throw in there.
ctm is offline   Reply With Quote
Old 06-17-2008, 07:17 PM   #5
mtn_wrangler
dont have the money to throw at it and i just want to get it on the road again. i dont think the tranny is bad because i can get it through the gears minus reverse and fifth. and even then when i picked it up it wne through those gears too. plz no ragging or telling me upgrade the tranny. i just could use some help
Old 06-17-2008, 07:38 PM   #6
northjeep
Jeep parking ONLY
northjeep's Avatar
I can only help you by saying the same thing as ctm.
It's worth it to find the NV3550 or ax-15 and trash that Peugeot.
I don't know what to tell you about the symptoms you're having.
I'm guessing it's a shift fork alignment issue.
perhaps a bent fork?
or a worn linkage?
Truly though you'll spare yourself a lifetime of anguish and pain by ELIMINATING the Pukegoat.
-NorthJeep - >> Just Enough Essential Parts
RED Jeep Club member - YJ Club - 258's Unite
northjeep is offline   Reply With Quote
Old 06-17-2008, 08:54 PM   #7
mtn_wrangler
thank you for trying to help. im still sticking with the stock just because its there and worse comes to worse im sure i can combine the two trannys and make one good one if it is something on the inside that i cant just fix through the top hole
Old 06-24-2008, 10:14 AM   #8
philly5eagle
1987 YJ Wrangler
thanks in advanced
joe
You said it was like it was in reverse and you pulled the shifter out and put it in neutral so it was locked. Then you fixed it. What did you do to "fix it"
87 yj 4.2 5spd peugeot,(has to go soon), 33" pro comps, 3"bds susp, 2"body, M/C 2100, HEI, and now determined it has a 4.0 head and exhaust
philly5eagle is offline   Reply With Quote
Old 06-30-2008, 01:38 AM   #9
mtn_wrangler
to fix it i would realign the shifter fork for 5th and reverse so that it would be in neutral again. what the root of my issues was the shifter. the cherokee ba 10/5's were built just different enough from the wrangler's ba 10/5's that they used a different shifter. so i took a cherokee shifter and slid it in and it shifts perfectly now. i had to bend the cherokee's shifter to make it fit with the center console in place because i cant get the two sections to separate but it actually works really well so im going to leave it like it is.
Glock Forum
