transmission issues? - JeepForum.com
post #1 of 5 Old 08-31-2011, 04:31 PM Thread Starter
ragincajin336
Maybe this was posted before and i am just too lazy to seek it out but here is the scoop:
I think I know what is going on, but I want yall's ideas, Today while driving around looking at the downed trees and power lines from Irene and my jeep started making a grinding noise in 1 and 2. I brought it home, let it sit for a while, then went out to get dinner and experiment with symptoms and here is what I have:
1. When working the clutch out to idle in first, the tranny makes a groaning noise, then moves like normal, kind of acts like the idle is set really low.
2. In second the tranny makes a grinding noise as I ease onto the gas and ease out of the clutch.
3,4,5. As I work through each gear, there is a slight groan as the clutch comes out and I go on full gas.
Other notes - It seems to grind in low gears if I have any clutch on as I work the gas. Lastly, In the higher gear range, there does not seem to be any real affect on performance.
Riddle me this.....
ragincajin336 is offline
post #2 of 5 Old 08-31-2011, 05:00 PM
Fenix85182
Fenix85182's Avatar
Sounds like the synchros are getting tired in first and second gears. In my first AX-15 the syncros failed in gear 4 and 2 first, as was noticed by difficult downshifting.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #3 of 5 Old 08-31-2011, 07:55 PM
ridgeghost
same exact thig is happening to me too, id agree that its the synchros. mainlyu because 1st and 2nd gears are used the most. but i have about 200,000 on this tranny and its been in 3 j33ps, so as i see it.... its about time for one anyways.
ridgeghost is offline
post #4 of 5 Old 09-01-2011, 06:26 AM Thread Starter
ragincajin336
So what is the fix?
Do I have to replace the whole tranny or is it possible to break it down and rebuild?
If I can rebuild, any idea how much and where I can get the synchros and a good place to find a blown up diagram for it?
post #5 of 5 Old 09-01-2011, 08:34 AM
Buckshooter
Buckshooter is offline
clutch , gear , tranny , transmission
transmission issues? knightwolf654 TJ Wrangler Technical Forum 17 11-11-2010 05:22 PM
Transmission Issues.... clemsonfan16 YJ Wrangler Technical Forum 12 03-15-2010 10:31 PM
transmission issues mtn_wrangler YJ Wrangler Technical Forum 8 06-30-2008 12:38 AM
Transmission issues.... mikecassidy1975 TJ Wrangler Technical Forum 3 11-05-2007 12:24 PM
Transmission issues jonnyri YJ Wrangler Technical Forum 4 09-29-2005 05:14 PM
