Transmission isssue - JeepForum.com
post #1 of 2 Old 08-17-2017, 08:27 PM Thread Starter
yooperbob
Transmission isssue
My 1995 Wrangler 4 cylinder has what appears to be some what of common problem. The thing grinds going in to 5th gear and pops out. Hard to get in to reverse at times & 3rd also. My buddy offered to give me a hand rebuilding it. What parts do I need to get this right again? Is there a kit to cure this? I normally deal with Rock Auto.
yooperbob is offline
post #2 of 2 Old 08-18-2017, 09:57 PM
RIPSAW
You need to start with a rebuild kit. I assume your 95 has the same AX5 mine has. Since your's is popping out, bet you may find some more parts broken also. Lot of nice rebuild video's on Youtube. Will need a press and a collar bearing puller.
I am going to do my clutch, flywheel and put new syncro in mine shortly. Hopefully, an expert will chime in on my part source as OK. Lot of work to put junk in there.
My post count is too small to post link but the kit I am looking at is Allstate gear. Part number is BK161LAWS-PLUS
16 Crosstrek, 04 Tacoma Reg Cab 4x4, 04 Harley Softail Deuce, 93 YJ 2.5 AX5
RIPSAW is offline
