transmission HELP!!! - JeepForum.com
post #1 of 2 Old 06-21-2004, 11:44 PM Thread Starter
4wheelinfool
4wheelinfool's Avatar
1980 CJ5
I have a problem, my tranny grinds when i go into 3rd gear, thats the only gear it does that in. It doest grind when i put the shifter in gear slow, but when i go into gear at a normal speed of moving the shifter it grinds. WHAT IS WRONG??? PLEASE HELP ME??? i am suppost to be going to las cruces to rock crawl in 2 weeks...
4wheelinfool is offline
post #2 of 2 Old 06-22-2004, 12:09 AM
SiRI
my buddy had a similar problem with 2nd gear, he bought some BG Syncro Shift Transmission fluid and the grinding stopped
SiRI is offline
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 05:10 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 08:43 PM
How to tell which transmission you have. GilpinTJ TJ Wrangler Technical Forum 1 06-19-2007 11:41 PM
transmission CRAZYJ1988 YJ Wrangler Technical Forum 12 01-31-2006 02:36 PM
Need help with transmission longdecember YJ Wrangler Technical Forum 13 01-24-2006 11:38 PM
