Transmission grind when engaged downhill - JeepForum.com
post #1 of 1 Old 10-10-2011, 10:35 PM Thread Starter
anklenawer
Alright here we go...
95' 6cyl 4.0l - 166k ( please hold applause)
have been having some problems with clutch, so i replaced both master/slave cylinders and everything was good until...
driving home, having trouble downshifting to 2nd to slow me down, just won't go into gear, feel it grinding.
now i am noticing that when the transmission is slowing me down ( downhill - mostly 2nd and REALLy 1st gear) it will grind grind grind.... feel it on the clutch pedal and in the shifter.
getting into gears isn't that great, sometimes have to double clutch, but usually no problem.
couldn't get T-case open to check fluid, but tranny was greay and gross.. drained as best as i could, and filled it with lucas additive, ( i know) and didn't change a thing
before i do anything crazy like take it to a shop, what should i be looking for ?
anything else i should do before i get it rebuilt? and when i ask for quotes, what should i be asking quotes for?
thanks for the help guys!
Jeepers, keep waving! ( even in Hawaii)
anklenawer is offline
grinding , synchros , tranny , transmission
How do you brake downhill! clg82 TJ Wrangler Technical Forum 23 05-22-2011 03:19 PM
Soft top going downhill- what to replace with? Xpress YJ Wrangler Technical Forum 24 03-28-2011 12:27 AM
Transmission not fully engaging, and second gear grind. Flynnster TJ Wrangler Technical Forum 8 05-06-2009 09:44 PM
Heat went downhill ninemili22TJ TJ Wrangler Technical Forum 12 11-27-2008 01:46 PM
My luck seems to be going downhill... Jim Shanks TJ Wrangler Technical Forum 10 02-27-2004 01:20 PM
