Transmission Fluid Question - Page 2 - JeepForum.com
post #16 of 94 Old 01-13-2013, 03:56 PM Thread Starter
Gozz
Hey guys so far so good.
I'm at the point where I need to remove the seal though and I'm having such a hard time with it.. I've been using a flat head screw driver and a hammer to try get under the metal to push out the seal but it's on there really tight (I'm not hitting super hard because I don't want to harm the transfer case itself), none of my screw drivers fit though.. Is there a way to do it from the inside of the seal? Like fitting in a screw driver and pulling it out while not harming the transfer case spline? Am I missing something?
Gozz is offline
post #17 of 94 Old 01-13-2013, 05:01 PM
Carralo1
Ya dont do that. you need to pull it out. Get something with a 90 degree or something curved in to pull it out corner by corner. What you really want is a seal puller, They sell them at any auto parts store for 5 or 6 bucks
Carralo1 is offline
post #18 of 94 Old 01-13-2013, 05:07 PM Thread Starter
Gozz
Ok I'll try to get in there and pull it.
The reason I was trying the way I was is because every video I saw did it with a screwdriver and hammer.
Anyways, round 2 here goes.
Thanks Carralo1 by the way.
Gozz is offline
post #19 of 94 Old 01-13-2013, 08:07 PM Thread Starter
Gozz
Alright I went out and bought a seal puller.
Really glad I did, it took the seal out in a second.
I went to Pep Boys after and asked for the part, they didn't have it in stock but they showed me this: http://www.pepboys.com/product/details/8839651/00678/
I just want to know if that's the right part because it doesn't look like the one I pulled out.
I brought it to them and everything. But it's the only rear output seal they had.
EDIT: Also I would like to make sure I got the right ATF. I bought Pennzoil ATF. There was also a Pennzoil ATF +4 and other weird stuff that I didn't know what it meant, so if anyone could just verify for me I'd really appreciate it.
Thanks guys
Gozz is offline
post #20 of 94 Old 01-13-2013, 08:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
National Seal part #4370N or equivalent.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #21 of 94 Old 01-14-2013, 01:44 PM Thread Starter
Gozz
Thanks Max hopefully the one I'm getting is compatible. If not I'll be buying online I guess.
Would anyone know if the ATF I picked up is ok for the Jeep? I don't want to blow anything up.
Thanks
EDIT: I'm seeing people say that it doesn't really matter what I put into the Transfer Case, but then seeing people recommending ATF +4, I don't even know what I have, it's just ATF with no numbers on it. What the heck did I pick up
Gozz is offline
post #22 of 94 Old 01-14-2013, 02:11 PM
Mark05059
doesnt matter for where your putting it... You have the right fluid for your transfer case.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #23 of 94 Old 01-14-2013, 03:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
^^^X2^^^
The transfer case does not require anything beyond basic lubrication, ANY brand/type ATF will be fine.
Max
Mean Max is offline
post #24 of 94 Old 01-14-2013, 03:44 PM Thread Starter
Gozz
Alright guys thanks.
I picked up my new seal, should I lube it or something around the edge or install it dry?
Can I just use ATF to lube it?
Gozz is offline
post #25 of 94 Old 01-14-2013, 04:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Definitely lube it. I use a small dab of grease & wipe it all around the lip area of the seal.
Max
Mean Max is offline
post #26 of 94 Old 01-14-2013, 07:29 PM
0verkillYJ
Max
You defenitly want the lips wet before you go jamming the shaft in it.
95 YJ, 2.5 AX15 conversion, 4.0 TB, SOA +1.5", 33" DC Crusher Tires, 8.8 Rear w/welded tubes + LSD, Spartan Locker HP30 Front w/solid axle swap, Rocky Road OTT kit, JKS Disconnects, AA SYE, Teraflex Shock Bar in Rear, 1/2" Boomerang Shackles, RE Add a Leafs, Homebrew Traction Bar, Monstalined in&out, LED Tail lights, 1700 Watt Stereo
0verkillYJ is offline
post #27 of 94 Old 01-14-2013, 08:30 PM
Carralo1
Bahahahahaahh
Carralo1 is offline
post #28 of 94 Old 01-14-2013, 09:33 PM
ROTTEN
Not sure if you did it yet but make sure you clean around the edges where the seal go.
Before I did a D30 oil seal and didn't clean off some old rtv and it failed.
I'm new
ROTTEN is offline
post #29 of 94 Old 01-15-2013, 12:37 AM Thread Starter
Gozz
Hey guys, just an update: everything is done!
So far no leaks and everything is running well. Hopefully it stays that way.
Just want to thank everyone that helped this noob figure it out. I feel like a king not gonna lie, even though it was a really easy thing to do hahah
I did rub the seal and the inside of where the seal goes really well, hopefully it's good enough to keep the seal in place, only time will tell.
Anyways now I've got a new problem.. Seems like when I put the Jeep in reverse it pops out of gear. This happened before in the Jeep but we got it fixed and I guess it's happening again.
Maybe it's time for a new thread though and honestly it isn't all that bad, maybe when I get more fed up with it because this seems like a tougher job that maybe I shouldn't do yet.
Gozz is offline
post #30 of 94 Old 01-15-2013, 12:43 AM
ROTTEN
How did they fix it? Linkage?
I'm new
ROTTEN is offline
