Transmission Fluid Change - JeepForum.com
post #1 of 6 Old 05-05-2009, 10:23 PM Thread Starter
EricYoung
I have been told several different things. can you put 10w-30 motor oil in when changing the trany. I bought some penzoil sincromesh because of some grinding problems that i have. Is that what i should fill my transmission fluid with? and can i change my transfercase fluid with the same penzoil sincomesh?
Thanks for your replies
EricYoung is offline
post #2 of 6 Old 05-05-2009, 10:32 PM
plyguitar45
i put syncromech in my tranny.
it helped a little with my grinding.
but for the transfer case and such, check the FAQ.
- New Jeep :D-
3.7L '04 Manual Liberty KJ, all stock
-SOLD MY JEEP :(-
2.5L Red '91 YJ w/
, 2" BL, 31" MT Baja Claws, Superwinch LP8500, RH4x4 Front Bumper, JKS Quick Disco's, Rampage Nerf Bars
plyguitar45 is offline
post #3 of 6 Old 05-05-2009, 10:34 PM
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
Automatic trans fluid is what is called for in the transfer case.
LB
_____________________________________
I own a Jeep, it's red and has big tires
lbsnowryder is offline
post #4 of 6 Old 05-05-2009, 10:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
This may help.
AX-15 tranny drain
AX-15 tranny fill plug
NP 231J transfer case drain & fill plugs.
And here's some differential gear oil change info.
http://www.jeepforum.com/forum/f12/basic-diff-lube-maintenance-728231/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 6 Old 04-03-2010, 12:58 AM
fallenbirdbeak
How many quartz do I need to fill up a manual transmission on a 1990 YJ? I'm using penzoil synchromesh to help with grinding, but the Pep-Boys computer said I needed 7. It doesn't sound right to me. Any help is appreciated.
My Jeep doesn't get me laid, but who cares.
My goal in life is to be able to work on cars like Tony Starks from Iron Man.
fallenbirdbeak is offline
post #6 of 6 Old 04-03-2010, 05:34 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
From the YJ FAQ:
What fluids do I use and how much do I put in my Jeep?
*Axles:
- Gear oil - 80 weight for light duty and normally cooler climates - 90w120 weight for heavy duty and normally warmer climates Note: Some rear axles are equiped with factory posi - a limited slip additive must be put in with the gear oil to extend and protect the limited slip action
Dana 30 = 2.5 pints
Dana 35 = 3.5 pints
Dana 44 = 4.0 pints
*Engines:
- 10w30 for good general usage in most climates
- 5w30 for those colder climates (when temps are below freezing for extended periods of time)
2.5L = 4 quarts (w/ filter)
4.0L = 6 quarts (w/ filter)
4.2L = 6 quarts (w/ filter)
*Transmission (standard):
- 80 weight gear oil but most recoment Redline MT 90 to protect the interals better. 75W90 is listed by some but the 80W is just cheaper to find with no ill effects.
AX-5 = 3.3 quarts
AX-15 = 3.25 quarts
BA-10/5 = 2.45 quarts
*Transmission (automatic):
- Automatic Transmission Fluid (ATF) Dexron III
TF 904 = 4 quarts
TF 999 = 4 quarts
*Transfer case:
- Automatic Transmission Fluid ATF+4
231 = 2.2 pints
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Transmission Fluid Change Skeezer TJ Wrangler Technical Forum 13 11-28-2006 07:04 PM
99 Transmission fluid change... ((~JEEP~)) TJ Wrangler Technical Forum 0 08-13-2006 10:49 PM
transmission fluid change?? UTmike TJ Wrangler Technical Forum 2 05-27-2006 03:22 PM
Transmission Fluid Change JungleLarry YJ Wrangler Technical Forum 15 03-11-2005 10:26 AM
Should I change my Transmission Fluid Dctjwrangler01 TJ Wrangler Technical Forum 1 06-19-2004 06:56 PM
