Transmission Crossmember - JeepForum.com
post #1 of 6 Old 04-13-2015, 05:46 PM Thread Starter
vgilbertson
Evening
Working on my AW4 conversion and need to make a cross member. I can use the Cherokee cross over but can only get the 2 skid plate mounting bolts. will the two 1/2" bolts be sturdy enough to hold?
Thanks
vgilbertson is offline
post #2 of 6 Old 04-14-2015, 08:43 AM
dadstoy
I used my stock skid plate and drilled holes for the tranny/skid support. Worked fine
dadstoy is offline
post #3 of 6 Old 04-14-2015, 08:53 AM
dadstoy
Also, the Cherokee t-case is clocked different than your YJ t-case. I had to "notch" my skid because the Cherokee t-case was lower than the YJ
dadstoy is offline
post #4 of 6 Old 04-18-2015, 07:21 AM Thread Starter
vgilbertson
Dadstoy - did you use the rubber mount?
post #5 of 6 Old 04-18-2015, 02:51 PM
Opihi59
from here it gets rough
Opihi59's Avatar
You can simply re-drill the mounting holes for the T case in the back end of the transmission in these situations to re-clock it. It's not the T case that is clocked differently per se, it is the bolt holes in the back end of the transmission from XJs that are different.
If it is a T case from an XJ, it will be the same orientation as for a YJ, but if it is a TRANSMISSION from an XJ, the T case will bolt to it in a 10 degrees (driver's side down) lower position. From what vehicle did you source your AW4?
OP, can you post up any photos of what it is you are trying to come up with a solution for?
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #6 of 6 Old 04-18-2015, 03:16 PM
Opihi59
Opihi59's Avatar
Just looked at a few of your other threads and see you've been putting this together for a while, I think I read that your AW4 came from a 96 XJ w 100K miles. I know this swap is an AW4 into a TJ, but there may be some helpful pointers on there. There are a few other AW4 swaps available online as well.
Opihi59 is offline
