-   -   Transmission/clutch? something else? (http://www.jeepforum.com/forum/f12/transmission-clutch-something-else-1568699/)
Shellb2414 08-29-2013 11:04 AM
11 Attachment(s)
I have a 94 wrangler and a few years ago I lost 5th gear. Still drove fine, shifted fine, all was well except 5th gear. Well then it started to pull when it was in first gear. Almost like an automatic being put in gear. Then reverse became a problem it wouldn't go in. If I put it in reverse before I started the engine it was fine. Reverse while engine is on is not possible. Also, as soon as engine is on it starts pulling in the reversed gear. Most times I have to turn the jeep off to get it back out of reverse. I have done some work on other areas and I am really trying to learn so thank you in advance for listening and any and all advice.
jokerchief462 08-29-2013 11:31 AM
Clutch problems. Could be asimple as servicing the master and bleeding or you could need a new clutch. Try filling and bleeding. Look for leaks on the firewall inside the cab by the peddles. Look underneath drivers side bell housing where the slave cylinder is mounted. If no leaks service as required and bleed. If that doesn't solve the issue you may be in for a new clutch.
Shellb2414 09-02-2013 10:43 PM
11 Attachment(s)
Thanks for your reply! I just did some searching and it seems for my year you can't actually bleed and refill but just replace. Is there any way to tell if the master has gone bad. Or maybe I should just replace it. thanks again!
Shellb2414 03-29-2015 01:25 PM
11 Attachment(s)
Changed out my master and slave, worked like a champ...til the next problem lol?
The time now is 12:04 PM.
