transmission clunk in every gear just as soon as the clutch engages. - JeepForum.com
post #1 of 32 Old 11-19-2011, 12:56 PM Thread Starter
jakemerritt
I think it might be the synchronizing gear??? If I shift at 2500 hundred rmps I have no clunk in any gear till I hit 5th then it clunks. Any other rpm it clunks every gear.
OIIIIIO
jakemerritt is offline
post #2 of 32 Old 11-19-2011, 02:07 PM
steelman10
Check your transmission mount.
steelman10 is offline
post #3 of 32 Old 11-19-2011, 02:53 PM
rocketboy
rocketboy's Avatar
Maybe bad u-joints in the rear driveshaft?
rocketboy is offline
post #4 of 32 Old 11-19-2011, 03:38 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
My money is on the torque arm stud, missing, damaged or loose.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #5 of 32 Old 11-19-2011, 03:55 PM
oldtime_ironman
X 2
oldtime_ironman is offline
post #6 of 32 Old 11-19-2011, 05:29 PM Thread Starter
jakemerritt
Lol ok torque ARM stud? Where is it? if bad how much? (Ball park) why would it mess up at any rpm but 2.5 hundred rpms?
OIIIIIO
post #7 of 32 Old 11-19-2011, 06:23 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Torque arm stud lives right next to the transmission mount, driver's side and bolts through the skid plate. You should see the bottom nut under the skid next to the 2 tranny mount nuts. Stabilizes the drivetrain when it tries to twist (torque) under acceleration. Drivetrain won't twist as much if you're already up to speed....
Seen here at the top center of the display picture. The 2 rubber bushings and nuts go with it.
http://www.quadratec.com/products/56003_04.htm
You may be able to find just the stud itself.
Oh, and try to fill out your profile as much as you can...we're flying blind here. You do have a Wrangler, right?
Feetwet is offline
post #8 of 32 Old 11-19-2011, 07:00 PM Thread Starter
jakemerritt
Sorry yea I just bought a black 95 yj 2.5l. I call her the dark night. This Is my first day on this forum. Thanks a ton for all the info. Now I don't have to fly blind or alone!
OIIIIIO
post #9 of 32 Old 11-19-2011, 07:07 PM
oldtime_ironman
FWIW the torque arm stud can be an easy fix with just hardware store stuff. Mine's loose about 1/4 inch and I get a nice thunk every time I take off. It'll tear up the trans mount if I don't tighten it back down. The mount itself is just a $20 piece of rubber with a couple bolts in it. Welcome to the forum, you just found one of the best jeep sites anywhere!
post #10 of 32 Old 11-19-2011, 07:40 PM Thread Starter
jakemerritt
Does it clunk when you shift?
OIIIIIO
post #11 of 32 Old 11-19-2011, 07:44 PM
oldtime_ironman
Yeah but not as much when I'm going faster. Its mostly noticable in 1st thru 3rd.
post #12 of 32 Old 11-19-2011, 07:47 PM Thread Starter
jakemerritt
Awesome thanks a ton!! One last question jeep parts and accessories any good web sites?
OIIIIIO
post #13 of 32 Old 11-19-2011, 08:06 PM
oldtime_ironman
www.quadratec.com
www.jeep4x4center.com
Those are 2 of the largest and most popular. They have literally everything clear back to the WW2 jeeps.
post #14 of 32 Old 11-19-2011, 08:41 PM Thread Starter
jakemerritt
Hahaha That's sweet!
OIIIIIO
post #15 of 32 Old 11-25-2011, 04:27 PM Thread Starter
jakemerritt
Torque arm stud gone! Replace now or is it a big deal?
OIIIIIO
