Transmission to Bell Housing Bolt ID 87' - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Transmission to Bell Housing Bolt ID 87'
15 x 8 Black D-Window Steel Wheels Set of 4Truc-Lite LED Headlights! OCONEE OFF-ROAD 706-534-9955USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 09-02-2010, 06:54 AM   #1
mxracer23
1987 YJ Wrangler
Can anyone tell me what size, pitch and length bolts are used to secure a manual transmission to the bell housing on a 87'. It has a ford NP 435 swap done by the previous owner and there is only 1 bolt holding the transmission to the bell housing. I am trying to avoid taking it out and dropping the transmission to ID the bolt.
Thanks!
mxracer23 is offline   Reply With Quote
Unread 09-03-2010, 04:02 AM   #2
mxracer23
1987 YJ Wrangler
Ttt
