transmission ax15 BFH? you be the judge - JeepForum.com
post #1 of 7 Old 10-20-2012, 03:53 PM Thread Starter
riverhippy
I could use some input on this problem
i just put back together an ax15 trans. (not a rebuild, just tore down and reassembled...long ugly story)
fully reassembled bench test:
1st gear: frozen. no movement or turning
2nd : quiet, good rotation
N : rotates, chattering(like a loose shift fork running across gear teeth)
3rd :chattering, good rotation
4th :chattering, good rotation
5th :chattering, good rotation
R : quiet, good reverse rotation
obvi something's amiss. i know ill be pulling it apart again, does anyone have any thoughts about the possibilities of where to start lo0oking?
i hope someone sez i misaligned the shifter or something
riverhippy is offline
post #2 of 7 Old 10-20-2012, 07:12 PM
pete1991YJ
That sounds like a question for MeanMax... pm him maybe? he knows the internals better than anyone
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #3 of 7 Old 10-21-2012, 08:18 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I suspect an issue with the 1-2 shift hub. While engaged in 2nd gear all is fine, but any other forward gear has a conflict. It's worth noting that reverse uses the 1-2 shift collar for a gear, and there's no chattering in reverse either.
Bottom line, yank it apart.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 7 Old 10-21-2012, 10:24 AM Thread Starter
riverhippy
Max
thanks max. i found the chattering problem. do you think the shift fork being behind the reverse idler gear instead of in the gears groove would cause the 1st gear not to turn?
post #5 of 7 Old 10-21-2012, 10:47 AM Thread Starter
riverhippy
Max
i hope this is a better shot
post #6 of 7 Old 10-21-2012, 06:35 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, that's yer problem right there! The reverse shift fork being out of it's groove is causing an issue with the 1-2 shift hub.
Max
Mean Max is offline
post #7 of 7 Old 10-24-2012, 09:31 PM Thread Starter
riverhippy
Max
maxi to put this behind my 2.5 i need a dakota housing, the hardware for an external slave cyl and the pilot bushing http://www.advanceadapters.com/produ...d-x-950-thick/
ax15 , boobs , readtheinstructions , sometimes i touch myself. , toofatformypants
