transmission alignment - JeepForum.com
post #1 of 6 Old 06-22-2013, 10:13 PM Thread Starter
Ranjo
Replaced internal slave cylinder today. Having trouble getting transmission to align with engine. Any suggestions?
Ranjo is offline
post #2 of 6 Old 06-22-2013, 10:14 PM Thread Starter
Ranjo
4.0 and 5 SPD pukit
Ranjo is offline
post #3 of 6 Old 06-22-2013, 11:38 PM
140mower
Not sure if this will help you, but what has worked for me is to use two pieces of all-thread or bolts with the heads cut off and thread them into the block to use as extra long alignment dowels. Be sure to install them in holes that they can be removed from after trans has been installed. Do NOT force the trans against the block using bolts, if it won't slide in relatively easily (tongue held right, stars aligned etc) something is out of whack and must be addressed before something is damaged.
edit; If your engine is original then it is 4.2l not a 4.0l, similar, but totally different animals.
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #4 of 6 Old 06-23-2013, 06:29 AM Thread Starter
Ranjo
Thanks..it is 4.0... engine swap
Ranjo is offline
post #5 of 6 Old 06-23-2013, 11:22 AM
pasinbuy
What other work did you do other than the slave?
Clutch, etc. ?
pasinbuy is offline
post #6 of 6 Old 06-23-2013, 09:24 PM Thread Starter
Ranjo
Got it done. Balanced trans on my body so it could float. Went right in!
Ranjo is offline
