-   -   transmission alignment (http://www.jeepforum.com/forum/f12/transmission-alignment-1540076/)
Ranjo 06-22-2013 10:13 PM
Replaced internal slave cylinder today. Having trouble getting transmission to align with engine. Any suggestions?
Ranjo 06-22-2013 10:14 PM
4.0 and 5 SPD pukit
140mower 06-22-2013 11:38 PM
Not sure if this will help you, but what has worked for me is to use two pieces of all-thread or bolts with the heads cut off and thread them into the block to use as extra long alignment dowels. Be sure to install them in holes that they can be removed from after trans has been installed. Do NOT force the trans against the block using bolts, if it won't slide in relatively easily (tongue held right, stars aligned etc) something is out of whack and must be addressed before something is damaged.
edit; If your engine is original then it is 4.2l not a 4.0l, similar, but totally different animals.
Ranjo 06-23-2013 06:29 AM
Thanks..it is 4.0... engine swap
pasinbuy 06-23-2013 11:22 AM
What other work did you do other than the slave?
Clutch, etc. ?
Ranjo 06-23-2013 09:24 PM
Got it done. Balanced trans on my body so it could float. Went right in!
The time now is 06:29 AM.
