transmission - JeepForum.com
post #1 of 13 Old 01-23-2006, 03:17 PM Thread Starter
CRAZYJ1988
transmission
when downshifting from 3rd to 2nd it wont go into second gear
just seems to grind and make weird noises
but when shifting from 1st to 2nd it goes in perfectly fine
what could be causing this
its a 1990 4.2 i believe its a ax 15 tranny
anything helps
1990 YJ
3.5 inch superlift
1/2 inch HD shakles
3 inch BL =/
35X12.50 BFG Mud Terrains
4.2 L
CRAZYJ1988 is offline
post #2 of 13 Old 01-23-2006, 03:23 PM
Fenix85182
Fenix85182's Avatar
How many miles do you have on it? Could be the synchromesh on second gear. Second and fourth are the first to go on the AX15.
They swapped tranmissions half way through the 1989 production year, so you definitely have the AX15 if it's still the stock transmission.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #3 of 13 Old 01-23-2006, 03:35 PM
naviathan
My 92 does that. Doesn't grind when down shifting, but won't go into gear until I get below a certain speed. Doesn't like to go into first until I'm at a complete stop and when it's cold it grinds in 2nd.
SOLD - Maybe I can afford this game when I'm old and rich.
naviathan is offline
post #4 of 13 Old 01-23-2006, 03:37 PM
dos0711
dos0711's Avatar
Same here.
2000 Wrangler TJ, 4.0 6 cyl, A/T, G2 Dana 44s, ARB Lockers, 4.10 ratio
dos0711 is offline
post #5 of 13 Old 01-23-2006, 03:52 PM Thread Starter
CRAZYJ1988
it might be cause its cold because it just got "cold" in houston you know like mid 40's 50's
so im just going to check the fluid and change it and wait it out
thanks guys
1990 YJ
3.5 inch superlift
1/2 inch HD shakles
3 inch BL =/
4.2 L
post #6 of 13 Old 01-23-2006, 05:51 PM Thread Starter
CRAZYJ1988
so the bolt stripped on the transmission to put fluid in it
any ideas on how to fix it
1990 YJ
3.5 inch superlift
1/2 inch HD shakles
3 inch BL =/
4.2 L
post #7 of 13 Old 01-24-2006, 08:49 AM
paintguy
vice-grip the stripped bolt and then get a new one.
paintguy is offline
post #8 of 13 Old 01-24-2006, 09:18 AM
ohhpe
mine does the same thing.. ax-15
i just match the rpms when shifting into second.... example... driving in 3rd, slowing down take out of 3rd gear, let clutch back out, rev pedal to about 2200 rpms or wherever yours works best, then push in clutch and should slip right into 2nd with ease while your still at the rpms....
i havent tried switching the tranny fluid yet, let me know if it helps!
95 yj 6" lift, 34" truxs mts
2005 WK Limited 5.7L Hemi. 2" day star lift awaiting tires and wheels for installation.
ohhpe is offline
post #9 of 13 Old 01-24-2006, 09:49 AM
MCJeeper
I have the exact same probalblem when shifiting into 2nd then have to be basicaly be stoped to go into 1st. I have had this problem ever since i bought the jeep a little more than a year ago. let us know if changing the fluid helps.
92 YJ 4.0 I6
01 Suby 2.5RS
MCJeeper is offline
post #10 of 13 Old 01-24-2006, 10:00 AM
naviathan
I just put fresh 80-90 in mine and it's still the same. The fluid that came out was milky like it got water in it somehow, but aside from 1st, when it's cold and downshifting everything else works great.
(I know, that's like saying virgins are great in bed except they don't know anything and bleed all over the place...)
post #11 of 13 Old 01-24-2006, 12:08 PM
flagstaffjeeper
yeah, like ohhpe said, try to double de-clutch when you are downshifting from 3rd to second. although you are supposed to have a syncromesh tranny, the 2-3 syncro could be going out. double de-clutching will help to match the revs and should make the shift smoother. shifting like this is kind of weird at first, but it quickly can become second nature, and it sounds cool, too.
Current Jeep: 2006 Unlimited Rubicon
Previous Jeep: 1981 CJ7, 4.2L, Muncie SM465, Dana 300 t/c, Dana 30 Front, AMC 20 Rear
flagstaffjeeper is offline
post #12 of 13 Old 01-31-2006, 12:15 PM Thread Starter
CRAZYJ1988
changing the fluid did help alot it goes right into 2nd now
mine has to be pretty much stopped to go into first too
but 4th gear is acting up bad it scratches horribly when i shift into 4th always does it now
maybe the synchros are going out on 4th or what ??
thanks for the help guys
1990 YJ
3.5 inch superlift
1/2 inch HD shakles
3 inch BL =/
4.2 L
post #13 of 13 Old 01-31-2006, 02:36 PM
psycho_emt_yj
very good possibility it is the synchros. oes it always grind in 4th? Mine went out in 2nd and 4th and i just drove it. Until it finally got stuck in first.
If you can't duct it, f*** it.
WHITE JEEP CLUB MEMBER #197
GEEK OFFROAD MEMBER v2.0
4-Slow 2.5L YJ Club #2
FF/EMT/Police/Military Jeep Club #123
Too Many Jeep Clubs Club Member#1
psycho_emt_yj is offline
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 05:10 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 08:43 PM
bad transmission? OutDoorDawg TJ Wrangler Technical Forum 12 07-08-2007 05:34 PM
How to tell which transmission you have. GilpinTJ TJ Wrangler Technical Forum 1 06-19-2007 11:41 PM
Need help with transmission longdecember YJ Wrangler Technical Forum 13 01-24-2006 11:38 PM
