transmission - JeepForum.com
post #1 of 6 Old 08-29-2011, 02:23 PM Thread Starter
sgtrandell101
transmission
ok so i have a weird light grinding that sounds like a train starting out when i start driving plus when i get up to speed the tub of the jeep that sit just above the transmission gets extreamly hot any ideas
sgtrandell101 is offline
post #2 of 6 Old 08-30-2011, 12:58 AM
moonshinefuel
Grind coffee with it?
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 6 Old 08-31-2011, 12:30 AM Thread Starter
sgtrandell101
Ha I'm not sure how that old taste
post #4 of 6 Old 08-31-2011, 12:34 AM
Jrcoyotes21
Does it grind when you shift?
Jrcoyotes21 is offline
post #5 of 6 Old 08-31-2011, 10:15 AM Thread Starter
sgtrandell101
no it doesnt
post #6 of 6 Old 09-01-2011, 11:17 AM Thread Starter
sgtrandell101
it only grands when i am in gear and the clutch is released. when it is in nutrel and clutch released it does not grind
bolt size for transmission mount to transmission? YJ89jeepTX YJ Wrangler Technical Forum 3 08-26-2011 08:22 AM
same transmission mount, new transmission g4x4xgeoff YJ Wrangler Technical Forum 0 02-22-2011 10:12 AM
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 05:10 PM
transmission duke04 TJ Wrangler Technical Forum 2 02-15-2008 09:33 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 08:43 PM
