Transfercase: 4hi works nothing else. - JeepForum.com
post #1 of 6 Old 11-03-2011, 12:07 PM Thread Starter
sdotcarter
When in neutral i engage 4 hi and it engages, and the dash light turns on. But it seems like I cant get it to go into 4 low. I try to wiggle/force it and it just stops. I dont have a repair manual on me right now but where should I start trouble shooting this? The jeep makes no irregular sounds when in 4 hi, but it turns like a *****. Is that a indication that the PO may of had a locker installed?
sdotcarter is offline
post #2 of 6 Old 11-03-2011, 12:29 PM
jmmorgan82
2009 JK Wrangler
Dumb question, but I only saw you mention 4low. Is 2hi working?
jmmorgan82 is offline
post #3 of 6 Old 11-03-2011, 12:50 PM Thread Starter
sdotcarter
Yes sir, sorry i didnt clarify.
post #4 of 6 Old 11-03-2011, 06:02 PM
Mark05059
when going to 4lo you need to pull the lever to the left and then back.. kinda like a z
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 11-03-2011, 06:52 PM Thread Starter
sdotcarter
Ran out and tried it. With some solid kidney punches to the shifter i got it to go in. Now it works like a charm. Im assuming the PO used this rig as a pavement pounder and never needed 4 lo, but my first time wheeling i woulda killed for it lol
Hey what are the symptoms of a locked front end? When the truck is in 4 wheeler and i try to turn at all it jerks and wants to go straight, i dont know hard to describe but its not line any other 4x4 ive driven.
post #6 of 6 Old 11-05-2011, 03:08 PM
Briteredjeepguy
The np231 transfer case is a part-time transfer case. When it's in 4wd, the two driveshafts are locked together at the same speed. This causes hopping when turning because your front wheels aren't turning at the same speed as the rear. This is also why you should avoid using 4wd on high traction surfaces.
Briteredjeepguy is offline
XJ transfercase in YJ CJ51973 YJ Wrangler Technical Forum 3 11-08-2010 08:28 AM
what is this on my transfercase? beachedjeepyj YJ Wrangler Technical Forum 24 12-03-2009 06:15 PM
Is the JK Transfercase a NP 241? rivers edge JK Wrangler Technical Forum 8 11-10-2009 04:01 PM
yj -xj transfercase RODNIK YJ Wrangler Technical Forum 3 09-23-2008 02:42 PM
Transfercase? ken334 TJ Wrangler Technical Forum 3 10-18-2006 04:27 PM
