Transfer case vacuum switch replacement...help - JeepForum.com
post #1 of 2 Old 06-06-2013, 07:11 PM Thread Starter
dswi
91 YJ
AX-15 / NP-231
Just replaced the transmission, t-case, clutch. (with parts from a 1993 JY...as an assembly)
With the new (to me) tranny/t-case installed jeep will not go in 4WD.
Went in fine before the swap (so it's not the CAD)
The only thing I can think of is the transfer case vacuum switch...How do I replace it with the one from my original t-case?
Is it just unplug the vacuum block, screw the switch out, screw the other one in, and plug vacuum block back in....or is it more than that??
4WD gearing is right (in low) but the front axle is not locked in. Front drive shaft is locked to the t-case when in 4WD, but not locked to the front axle...and no 4WD light on the dash (the bulb works)
Character is Who You Are When Nobody Is Looking!!
Darrin
dswi is offline
post #2 of 2 Old 06-06-2013, 07:35 PM
superj
Yes, unhook lines, unscrew, screw other in, replace lines. And the lines should be on a large plug so its actually just unplug one deal.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
