Transfer case vaccuum case switch - JeepForum.com
post #1 of 8 Old 07-10-2007, 11:54 AM Thread Starter
Hambne
Did a little search to find what im looking but nothing. I just did a sye conversion on my 91 ( np 231 ) and when it was put back together no 4wd. I figure that it was a vaccuum line broke. I has been replaced before i bought it. Im wondering if it is something inside the tc because when I pull into 4wd the front shaft turn. Is that correct. Also when in 2wd Ihave a vaccuum at the vaccuum switch at the axle but when placed into 4wd there is nothing on either vaccuum lines at the axle. Is there something in the tc that pushes on the check valve on the tc vaccuum switch ? I did replace the vaccuum but still had the same problem. Thanks for the help. Derek
Hambne is offline
post #2 of 8 Old 07-10-2007, 01:43 PM
timatoe
timatoe's Avatar
When you pull the lever for the TC the vac switch is actuated switching the vacuum. While some will say that the connector can't fit on the switch the wrong way, I did do it before. So make sure that the plug is back on right in the "keyed" spot. I would bet that's your problem, especially if it was working before.
Also stand by for everyone to tell you why you should get the posilock.
timatoe is offline
post #3 of 8 Old 07-10-2007, 04:03 PM Thread Starter
Hambne
Thanks I made sure that the plug was on right 3 or 4 times but still does the same thing
Hambne is offline
post #4 of 8 Old 07-10-2007, 08:33 PM
kloppk
Yes there is something inside the tcase that activates the vacuum switch.
You should have vacuum on the Right side of the axle vacuum motor in 2WD
and vacuum on the Left side of the axle of the vacuum motor in 4WD.
Sounds like you either have a break in the line from the vacuum switch to the Left side of the axle vacuum motor (yellow line) or you have a defective vacuum switch.
kloppk is offline
post #5 of 8 Old 07-11-2007, 11:51 AM Thread Starter
Hambne
Does anybody know what activates the switch for it to flop sides
Hambne is offline
post #6 of 8 Old 07-11-2007, 12:22 PM
Varnish
Varnish's Avatar
The switch in the tcase has a steel ball in the bottom that is pressed on by a cam attached to the shift bar in the tcase.
'06 LJ, '88 YJ
Varnish is offline
post #7 of 8 Old 07-11-2007, 01:23 PM
giggityjeeper
your vacuum motor on your front axle housing is prolly seized, happened to me 3 or 4 times before I swapped it out for posi lok.......the vacuum is there but the fork wont move inside the housing, so it wont ingage the 4x4
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #8 of 8 Old 07-11-2007, 04:36 PM Thread Starter
Hambne
Thanks guys for the help I want to get to wheel again before I make the trip across the big pond t the sandbox but probably. I know for a fact that the vaccuum is not there in 4wd because i took the vaccuum plug off the vaccuum motor and had vaccuum in 2wd but not 4wd. I think it should be the same amount of vaccuum,right?
Hambne is offline
Transfer Case/ Vacuum Switch budro69 YJ Wrangler Technical Forum 0 12-10-2009 07:34 PM
transfer case vac switch xxgunrunnerxx YJ Wrangler Technical Forum 7 12-08-2009 01:59 PM
transfer case switch? dwaynetm1 YJ Wrangler Technical Forum 3 05-19-2009 06:16 PM
Transfer Case Vacuum Switch badassf4i YJ Wrangler Technical Forum 3 08-27-2006 09:27 PM
Transfer case vacuum switch stephen reu YJ Wrangler Technical Forum 4 03-11-2003 10:52 AM
