transfer case vac switch - JeepForum.com
post #1 of 8 Old 12-08-2009, 11:24 AM Thread Starter
xxgunrunnerxx
Have not crawled underneath yet to check location of this switch, is it a bear to access from underneath or can it be accessed up top with the boot off. Not at the house or i would climb under and look
thanks in advance.
xxgunrunnerxx is offline
post #2 of 8 Old 12-08-2009, 11:28 AM
RebuildRookie
are you talking about the 4x4 vac switch?
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #3 of 8 Old 12-08-2009, 11:29 AM Thread Starter
xxgunrunnerxx
yes the 4x4 vac switch
post #4 of 8 Old 12-08-2009, 11:32 AM
RebuildRookie
yeah just pull the boot cover(s) off and if you want you can pull the plate also, to give you more room. It is located on the top, so getting to it from under the vehicle would be a pain in the ---
post #5 of 8 Old 12-08-2009, 11:34 AM Thread Starter
xxgunrunnerxx
Sweet thanks Rebuild
post #6 of 8 Old 12-08-2009, 11:51 AM
RebuildRookie
your welcome
and I am pretty sure its on the driver side. Its "easier" to get to still gotta wiggle a little
You will see the 4 colored lines bundled together.
post #7 of 8 Old 12-08-2009, 11:54 AM
RebuildRookie
and for future reference, you can bleed the master clutch cylinder there also.
post #8 of 8 Old 12-08-2009, 01:59 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here's the switch, on the driver's side at the top.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
transfer case switch? dwaynetm1 YJ Wrangler Technical Forum 3 05-19-2009 06:16 PM
Transfer case vaccuum case switch Hambne YJ Wrangler Technical Forum 7 07-11-2007 04:36 PM
where is my 'vacuum transfer case switch'? 92redyj YJ Wrangler Technical Forum 3 12-30-2006 04:36 PM
Transfer Case Vacuum Switch badassf4i YJ Wrangler Technical Forum 3 08-27-2006 09:27 PM
Transfer case vacuum switch stephen reu YJ Wrangler Technical Forum 4 03-11-2003 10:52 AM
