Quantcast transfer case switch removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > transfer case switch removal
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 05-18-2007, 01:37 PM   #1
kefurd06
k, i found it (driver's side on top of TC). now how do i remove it? i see a rubberized plug with four vacuum lines coming out of it (right?). didn't want to budge when i pulled on it and i'm not sure if that's what i should do anyway. so what now? tnx
kefurd06 is offline   Reply With Quote
Old 05-18-2007, 01:39 PM   #2
jeepin1995
jeepin1995's Avatar
are you talking about the vaccum lines on the t-case??? they just pull off
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 05-18-2007, 01:47 PM   #3
Monk89 94 I4
take a big *** vice grip and get it off, it unscrews normally.
94 was a great year for the yj, 2006 was a great year when i put the sport cage in it...
Monk89 94 I4 is offline   Reply With Quote
Old 05-18-2007, 08:16 PM   #4
kloppk
The rubber cop on the switch can be tough to get off.
Usually some wiggling it and rocking it back an forth will get it to come off.
It's keyed so it can only on on 1 way.
As posted above the switch itself is just screwed into the tcase.
kloppk is offline   Reply With Quote
Old 05-23-2007, 06:16 AM   #5
kefurd06
i tried yesterday but i couldn't get a pair of vice grips on it well enough to loosen it. there's just no room in there for turning either. anyone have a tip on how i can get the switch loose without taking things apart? maybe a large socket or somethin?
Old 05-23-2007, 03:01 PM   #6
bryan-2kevo
if you have the new one, just see what socket will fit onto it!!!
if not, i used an cresant wrench. it is a tight fit, but once it is cracked loose, you should be able to turn it by hand.
bryan-2kevo is offline   Reply With Quote
Glock Forum
