transfer case switch? - JeepForum.com
post #1 of 4 Old 05-18-2009, 05:38 PM Thread Starter
dwaynetm1
Has anyone replaced the switch on you transfercase the engauges the 4 wheel drive. I need to get mine out. I've got constant vac on the yellow line going to the plunger that engauges the front axle. I can see it from the boot that covers the stick shift is this my best route? It's in a pretty had spot to get to from under/on top of the skid plate with the linkage in the way. I've tought about going the posi lock route but I'd thought I would just pull the switch and see if alittle cleaner would free it up. Thanks
dwaynetm1 is offline
post #2 of 4 Old 05-18-2009, 06:51 PM
jeep-dangler
get rid of the finicky vacume setup and build ur own cable actuated posi lock contraption. U will not regret it if u read a bit and do it right the first time!!!!
1995 YJ 4.0L HO
760X U-jouints, homemade posi lock, homemade bumpers, modified hydraulic plow setup. RC 4" lift kit, 33" TSL swampers. No sway bar or rear track bar.
jeep-dangler is offline
post #3 of 4 Old 05-19-2009, 05:28 PM
kirksjeep
I swapped in a TJ electrical switch after my solid shaft conversion, and I did it with the skid plate in place. If I remember right it was a 7/8" or a 1" wrench. I remeber using a socket and a wrench, and it was tight, but it came out with out too much trouble.
kirksjeep is offline
post #4 of 4 Old 05-19-2009, 06:16 PM
shatteredsoul
Just did it today,my 4wd actuator was bad and I get a huge discount at work so for $5 for a new one I went ahead and got it.I just used a 1/2 ratchet and a 1 1/4" socket to get it loose,it wasnt that tight at all.Then I snugged the new one up and all is good now.Before mine would engage no problem but wouldnt disengage the front diff. Its not hard at all to get to it took literally 2 minutes to change it,it was harder lining up the vac hoses then taking the old one out and putting the new one in.Good luck
shatteredsoul is offline
transfer case vac switch xxgunrunnerxx YJ Wrangler Technical Forum 7 12-08-2009 01:59 PM
Transfer case vaccuum case switch Hambne YJ Wrangler Technical Forum 7 07-11-2007 04:36 PM
where is my 'vacuum transfer case switch'? 92redyj YJ Wrangler Technical Forum 3 12-30-2006 04:36 PM
Transfer Case Vacuum Switch badassf4i YJ Wrangler Technical Forum 3 08-27-2006 09:27 PM
Transfer case vacuum switch stephen reu YJ Wrangler Technical Forum 4 03-11-2003 10:52 AM
