transfer case swap - JeepForum.com
post #1 of 5 Old 04-29-2013, 08:20 AM Thread Starter
bob6987
transfer case swap
Can a transfer case Input Gear (21 spline) from a 2.5l 94 yj (sure its an ax5) be swapped with the Input Gear (23 spline) from a 91 4.0l 91 yj (sure its an ax15).
I just want to swap transfer cases between the two jeeps. I want to move my 94 suspension from the 94 to the 91 so i get a less beat up jeep and a 4l.
but still have the 94 functional with the 91 suspension.
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #2 of 5 Old 04-29-2013, 09:11 AM
SeanB95YJ
Should be OK
and while you're at it, swap your axles too (unless you've already regeared your 91) to get the 4.10s... edit - nevermind... read your sig AFTER I posted
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 5 Old 04-29-2013, 01:17 PM
LaddieHanus
Nope. The input gear changed in 94
http://www.novak-adapt.com/knowledge...nput_gears.htm
Laddie Hanus
2009 JKU Rubicon
97 TJ Sahara
89 YJ
2000 Dodge/Cummins Lance Camper
2004 GC Limited (Wife Jeep) 4.7 HO rebuilt 9/2016
LaddieHanus is online now
post #4 of 5 Old 04-30-2013, 07:34 AM Thread Starter
bob6987
Originally Posted by LaddieHanus View Post
Thank you for this info.
2012 JKU
bob6987 is offline
post #5 of 5 Old 05-01-2013, 06:34 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
You should however be able to swap the front half of the case's. This would give you the 23 spline input you need and the same rear you currently have. Lot's of people do that with a chevy 4.3" swap to get the 6 planetary gear upgrade.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
