Transfer Case shifter Hard to move! - JeepForum.com
post #1 of 8 Old 08-16-2011, 04:35 AM Thread Starter
Juvam
hello!
i bought 1995 yj last week
2.5" lifted
1" transmission drop
5 speed
np231 transfer case
4.0L
Transfer Case shifter Hard to move from (2H) to (4H) and harder in (N) and (4H)
the previous owner said that he changed the fork inside it.
my previous xj transfer case shifting was smoother than the YJ.
any idea
thanx in advance
Juvam is offline
post #2 of 8 Old 08-16-2011, 07:54 AM
Spuznick242
If he changed the fork inside chances are somethings wrong with the fork then. Never encountered a problem like this but it sounds like it would be a problem with the install he did possibly. Why did he change the fork in the first place?
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 8 Old 08-16-2011, 08:00 AM Thread Starter
Juvam
coz of ware on it
he toled me that
/l--, [____],_
l---L--_[]lllllll[]_
()_) ()_)==@=)_)
Welcome to http://www.liwateam.com/
Juvam is offline
post #4 of 8 Old 08-16-2011, 08:05 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Originally Posted by Juvam View Post
coz of ware on it
he toled me that
He messed something up. you might want to take it out and have a look. The t-case is very simple to remove.
but first, I would go underneath and have someone shift it. look for any binding in the linkage. Start with the easy things it could be.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #5 of 8 Old 08-17-2011, 12:33 AM Thread Starter
Juvam
I went underneath the jeep but nothing found.
But after the adjustment linkage become better than before.
Juvam is offline
post #6 of 8 Old 08-17-2011, 01:19 AM
Islander_child
The shifter is a pretty simple piece of equipment. More than likely its just a little rusty. Also the difference you feel in the shifter between a yj and your xj is because they use completely different shifters. YJ transfer case shifters are mounted to the transmission while XJ transfer case shifters are mounted to the body. And the "fork" you mentioned? Are you referring to the axle disconnect fork? If so that part shouldnt effect how hard the shifter is to move.
K.I.S.S. Keep It Simple Stupid.
Islander_child is offline
post #7 of 8 Old 08-17-2011, 01:29 AM Thread Starter
Juvam
Mode Shift Fork in side the transfer case.
/l--, [____],_
()_) ()_)==@=)_)
Juvam is offline
post #8 of 8 Old 08-17-2011, 02:44 PM
Islander_child
Oh sorry
Transfer case shifter mod? PA_LJ TJ Wrangler Technical Forum 3 11-08-2010 11:38 PM
Transfer case shifter... Sweeney TJ Wrangler Technical Forum 8 01-25-2010 06:46 PM
95 YJ Transfer Case Shifter F1504x2 YJ Wrangler Technical Forum 6 05-08-2009 10:15 AM
How much does the Teraflex Belly Up move the Transfer Case up, also Clayton MEnginerd TJ Wrangler Technical Forum 3 04-27-2008 03:17 PM
Transfer case shifter GroundAssault TJ Wrangler Technical Forum 10 12-20-2006 11:44 AM
