transfer case repair/replacement? - JeepForum.com
post #1 of 6 Old 12-15-2009, 04:58 AM Thread Starter
jmurds
New to the Jeep community, please forgive my lack of experience.
I picked up a 92 YJ (2.5L 4cl/5sp), all stock (my first Jeep ever!) about a week ago as a daily driver/running project. It runs great except for the fact that today the transfer case started making noise like the chain is slipping. I put it in 4wd for the first time today to get through some snow, then drove in reverse for a bit to ensure 4wd was off. Dirveability is the same as ever. The 4wd light is (and has been) stuck on all the time, but the Jeep itself is definitely in 2wd (when up on a jack, front wheels spin freely by hand). I've already ordered a Posi-Lok setup to replace the retarded (and evidently damaged) vacuum system.
Anyways, I'm concerned about the noise from the transfer case. It sounds like the chain is slipping over worn gears, though only in low rpm range (esp. starting out in 1st gear). It drives the same as it has since I've owned it. I assume this noise is not normal or desirable, but is this a common occurence, and/or one I can live with? I'm going to change the fluid in the transfer case tomorrow and check for any major chunks of metal, does anyone know if there's anything in particular I should look for?
This forum seems to have a lot of great advice from a lot of experienced Jeep owners. Can anyone tell me if simply servicing the transfer case will postpone the need for replacement, or should I just swap the thing out? I don't plan on doing any serious 4-wheeling until this coming summer, so having 4wd isn't critical for now.
If I need to swap the transfer case out, could anyone point me in the direction of a semi-detailed how-to guide? I've searched the forums, but can't seem to find a transfer case swap thread aimed at someone who's completely new to Jeeps. I'll be doing the swap myself, in my driveway, in the snow. I won't have the funds for a new/upgraded T-case until summer either, so I'll be doing a straight stock to stock swap with a junkyard replacement.
Again, any help at all would be appreciated. Thanks guys
jmurds is offline
post #2 of 6 Old 12-15-2009, 05:46 AM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
I usually start with this,
HAYNES TOTAL CARE MANUAL - JCWhitney
Then..when I find if it's unclear I search the specifics in here or dig deeper with Google...
Not an expert here by any means, and never was a mechanic, but that book has helped me understand and take my jeep apart...and will help me put it back together. This forum is great for the details the book misses...and much more!!
I will see if I can find you a link for another source....
hotelconucc93 is offline
post #3 of 6 Old 12-15-2009, 05:53 AM
hotelconucc93
2010 YJ Wrangler
Here's a neat play-by-play...still recommend the manual...
Jeep Wrangler - Rockland Standard Gear's NP231 Transfer Case - 4WD & Sport Utility Magazine
post #4 of 6 Old 12-17-2009, 12:53 AM Thread Starter
jmurds
Great find on the transfer case swap article. I picked up the Haynes manual, don't know how I ever lived without one. After changing the T-case fluid, which was low, the noise cleared up. Glad to know if it does break, it doesn't look too hard to swap out. Thanks for the help!
jmurds is offline
post #5 of 6 Old 12-17-2009, 01:03 AM
godzirra
replace it with a dana 300
U.S.M.C. : Travel agents to allah
godzirra is offline
post #6 of 6 Old 12-17-2009, 04:22 AM
hotelconucc93
2010 YJ Wrangler
You're Welcome!
I just pulled mine (whole drivetrain) but I am putting back an Atlas case...can't wait!!
advice on transfer case and u joint replacement bucky6 YJ Wrangler Technical Forum 9 01-04-2010 11:27 AM
Transfer case replacement eprovenzano TJ Wrangler Technical Forum 0 10-30-2008 07:31 AM
Transfer Case and Axle fluid replacement hunter44102 TJ Wrangler Technical Forum 2 09-10-2007 08:35 AM
Transfer case replacement 97TJ4.0MIKE TJ Wrangler Technical Forum 2 07-19-2007 09:16 AM
