Transfer Case Questions - JeepForum.com
post #1 of 3 Old 10-22-2002, 08:49 PM Thread Starter
Willis91YJ
Just wondering what I would need to do to put a t-case from a 94 XJ with an i-6 into a 91 YJ with the same motor. From what I can find the speedometer sending units are in different spots but wondering what else. Thanks in advance
Willis91YJ is offline
post #2 of 3 Old 10-23-2002, 08:13 AM
Bob J
Bob J's Avatar
1984
Did the XJ have part time or full time 4WD?
If it had part time you might have just have to keep the tail housing and maybe the main shaft off the YJ.
If it had full time the swap is going to be a lot more complicated.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #3 of 3 Old 10-23-2002, 11:29 AM Thread Starter
Willis91YJ
Bob,
It's an NP 231 which would lead me to believe that it is part-time. If thats teh case all I need is a yj tail housing and a drive shaft huh? Sounds good to me. Thanks bud
Willis
transfer case questions... roccomonte YJ Wrangler Technical Forum 8 06-30-2009 12:17 AM
ax-15 and transfer case questions Ironman23 YJ Wrangler Technical Forum 6 07-10-2008 10:53 AM
Transfer Case Questions paintballjerry TJ Wrangler Technical Forum 3 06-14-2006 08:18 AM
Transfer case questions true98jeep TJ Wrangler Technical Forum 1 01-29-2006 08:41 PM
Transfer case questions ProfessorCRX TJ Wrangler Technical Forum 6 12-25-2004 11:24 AM
