Transfer case question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Transfer case question
The Boss is away but Erin is here to STAY with a F.Y.S. SaIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-29-2015, 11:24 AM   #1
schaller
Just a quick one, if I run the engine with the transfer case off, will transmission fluid leak out.
Thanks
schaller is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 11:26 AM   #2
gotswap
yes, the tcase input seals the trans output
gotswap is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 11:53 AM   #3
schaller
thx
Unread 03-29-2015, 06:50 PM   #4
Joe Dillard
Electric Chair Operator
Care to explain?
OP - not likely - especially if the tranny is in neutral and its seal is good.
Lookie here, no leak
Joe Dillard is online now   Reply With Quote Quick reply to this message
Unread 03-30-2015, 11:27 AM   #5
Anticanman
The Thunder Chunky
Anticanman's Avatar
Thanks
Depends on your transmission. Fill in your profile
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 12:54 PM   #6
mike134
'88 4.2L must be peugeot BA10/5
mike134 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 02:10 PM   #7
Anticanman
The Thunder Chunky
Anticanman's Avatar
I had an 88 with a 4.2 and an auto
Unread 03-30-2015, 04:09 PM   #8
Mark05059
unless someone has changed it.... or its an automatic
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 07:04 PM   #9
baritone_mike
I had no issue with the AX-5 leaking fluid when the transfer case was removed for 3 months. I never did run the engine though.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 07:13 PM   #10
Mean Max
Don't poke the bear
Mean Max's Avatar
Care to explain?
Hey Joe! Sorry, but you're all wet on this one!
The input shaft of the transfer case seals up to the transmission rear seal.
Yes, it will leak fluid if you run the engine without the transfer case installed.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 07:16 PM   #11
Mean Max
Don't poke the bear
Mean Max's Avatar
No, it doesn't. ALL of the transfer cases seal the rear transmission seals of all YJ transmissions the same exact way.
Max
Unread 03-30-2015, 09:37 PM   #12
Anticanman
The Thunder Chunky
Anticanman's Avatar
Max
Guess ya learn something new every day. I didn't leak a drop of my ax15 when I pulled the transfer case off and started it in neutral. Perhaps I was either lucky or just really low on oil.
I wouldn't ever argue with Max. Where the heck ya been, man?
Unread 03-30-2015, 11:18 PM   #13
imstillatwork
my ax5 puked it's guts out when I pulled the t case. must have been a bad seal? I had no idea.
imstillatwork is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 01:50 PM   #14
adiubald
If the transmission is not level, all of the fluid will come pouring out of the back when you remove the transfer case. I have taken a 5w30 shower in the past.
In N, just the input shaft would be spinning so its believable that you would not be leaking out of the trans. With the clutch pedal pressed would be the best bet to not loose any fluid as nothing is spinning.
Mean Max is correct the counter shaft will also spin and with no load on the output shaft, it will spin too. I'm in the process of rebuilding my AX-5 and I confirmed this last night. Sorry for the confusion.
adiubald is offline   Reply With Quote Quick reply to this message
Unread 03-31-2015, 04:22 PM   #15
Mean Max
Don't poke the bear
Mean Max's Avatar
Not all accurate. The input shaft would indeed be spinning, but so would the counter shaft, and with nothing to keep it from spinning the output shaft would in fact be spinning in neutral from the viscous properties of the oil in the transmission.
Max
