Transfer Case Problem? - JeepForum.com
post #1 of 13 Old 04-21-2008, 02:12 PM Thread Starter
zach3713
Shifting in 4 LOW Problems
Something that happened to me lately has got me worried. I can't shift into 4wd lo, or neutral without putting the jeep in reserve and inching back a few. What happens is: If i'm driving forward, and then stop and try and pit the jeep in 4wd lo, it won't pull back. It feels like it's jammed. IF I put it in reserve, and slowly inch back and pull the handle, it'l drop into 4 lo.....anyone got any ideas?
zach3713 is offline
post #2 of 13 Old 04-21-2008, 08:47 PM Thread Starter
zach3713
No one has any clues?
zach3713 is offline
post #3 of 13 Old 04-21-2008, 09:00 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
does it not go in if creeping along going forwards? should do...
when i had my 231, sometimes it would shift, sometimes it would (when stopped)
now i have the atlas, it will not shift when stopped, it has to be rolling.
try rolling it forwards, put the tranny in neutral, and then try to shift the t/case and let us know!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 13 Old 04-21-2008, 11:18 PM
Brown Dog
Vendor
Brown Dog's Avatar
I suspect your shift fork (inside the transfer case) could be worn. Also, there are two plastic guides on the fork. If these break from wear things don't work right. I'm betting on one of the two
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #5 of 13 Old 04-22-2008, 12:20 PM Thread Starter
zach3713
OK, I tested it, it will only shift IF rolling backwards. Otherwise, nothing..impossible to pul back. I can pull it into 4wheel hi easy..like nothing is wrong, it's just anyhting past that point. How hard is it to check if it's the fork, and how hard to replace.?
zach3713 is offline
post #6 of 13 Old 04-22-2008, 01:30 PM
1995_4.5L Jeep
I have to be rolling to get my t-case to shift. No big deal, I don't look at it like it's broken.
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
1995_4.5L Jeep is offline
post #7 of 13 Old 04-22-2008, 01:38 PM Thread Starter
zach3713
The only thing that worries me is that this has just started...it's never required this previously.
zach3713 is offline
post #8 of 13 Old 04-22-2008, 01:42 PM
1995_4.5L Jeep
do you have a body/suspension lift kit?
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
post #9 of 13 Old 04-22-2008, 02:31 PM Thread Starter
zach3713
everything is stock, except within the last two weeks have installed lockers front and rear and the posi-lock cable system for 4wd engagement. Other than that, everything is like it was from the factory.
zach3713 is offline
post #10 of 13 Old 04-22-2008, 07:21 PM Thread Starter
zach3713
How hard is it to check the fork in the t-case?
zach3713 is offline
post #11 of 13 Old 04-22-2008, 08:22 PM
leftlanetruckin
XJ on 37's
drop the t/case and rip apart...
yeah it is a PIA, but if you want to check everything out correctly, that is normally the case my friend!
you in auburn wa or auburn mi? if washington, i get out there at times and could have a looksee, but never know where i am going next......
martin
post #12 of 13 Old 04-22-2008, 08:32 PM
USMC SouthernYJ
...or maybe Auburn, AL.
lol i have nothing to say on the topic, just wonderin if there was a fellow auburn jeeper.
94 YJ
- SOA 2.5" OME Springs, 8.8, 4.88's, 35in ProComp MT's on 15x10 ProComp StreetLock Wheels
Semper Fidelis
War Eagle!
USMC SouthernYJ is offline
post #13 of 13 Old 12-03-2008, 08:31 AM Thread Starter
zach3713
Yupppp Auburn, AL WAR DAMN EAGLE!
zach3713 is offline
Transfer Case problem mbojaj YJ Wrangler Technical Forum 3 07-28-2009 12:22 AM
Transfer Case Problem? aaron89yj YJ Wrangler Technical Forum 3 09-14-2007 05:09 PM
Transfer Case Problem Gurrenteed555 YJ Wrangler Technical Forum 3 06-06-2007 08:46 AM
transfer case problem 1rockhead YJ Wrangler Technical Forum 2 02-05-2007 10:18 AM
transfer case problem? BumbleBeeTJ TJ Wrangler Technical Forum 6 10-17-2004 05:02 AM
