-   -   Transfer Case Problem (http://www.jeepforum.com/forum/f12/transfer-case-problem-1365891/)
bpete123 05-07-2012 12:14 AM
took the yj offroading for the first time today and went into 4-H fine but will not go backinto 2-H no matter what I do i have tried everything...HELP
it goes down to Neutral and 4-L and back up to 4-H but not to 2-H
Rynfw100 05-07-2012 12:19 AM
Go underneath the vehicle and look at the linkage to see if there is any binding. Are you sure that you're not in 2-H? Or is the 4WD indicator light on?
bpete123 05-07-2012 12:20 AM
Light is on I am 100% sure it is in 4-H
Anticanman 05-07-2012 12:28 AM
It may not be in 4 high. Your shift fork may just be stuck because of a vacuum problem. Check to make sure the shifter is in the correct position. Then crack the central axle disconnect and see why your shift fork is stuck.
The time now is 10:51 AM.
