Transfer case planetary gear noise - JeepForum.com
post #1 of 4 Old 03-31-2009, 12:53 PM Thread Starter
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Ok so I was installing my SYE and I got the transfer case completely apart. While looking it over and cleaning out the internal components I spun the planetary gear and it spins ok but it seems to make a slight grinding noise and has a slight catch as it spins around. Since I have never taken these things apart I am not sure if this is normal gear noise, the gears appear ok from the outside but I haven't taken apart the input bearing and planetary gear assembly. Any ideas? Thanks
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
post #2 of 4 Old 06-23-2012, 09:31 PM
warehimer34060
2015 JK Wrangler
I have that exact same problem. Just looking for an answer!
warehimer34060 is offline
post #3 of 4 Old 06-23-2012, 10:14 PM
G30SFF250
Either run it or replace it.
It is a 20 year old piece of equipment.
Replace everything you are working on or just replace what breaks.
It is the never ending story. Replace before it causes further damage but how far is too far and how much money do you want to spend.
I can't figure it out myself. I like doing things right but I don't want to be that guy that has $40,000 in a Jeep that sells for $6,000.
Good luck my friend!
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #4 of 4 Old 04-11-2013, 08:06 AM
saylor
Bump anybody?? Same question
saylor is offline
Gear oil in transfer case? never0101 YJ Wrangler Technical Forum 20 03-13-2015 12:12 PM
planetary gear makes noise kah35503 TJ Wrangler Technical Forum 5 02-26-2009 10:04 PM
gear box/transfer case, g8ts YJ Wrangler Technical Forum 3 09-19-2008 09:36 PM
Transfer case noise bail315 TJ Wrangler Technical Forum 2 03-04-2008 08:15 AM
transfer case noise? decrepid13 TJ Wrangler Technical Forum 1 12-09-2004 09:38 PM
