Transfer Case Lowering help and advice - JeepForum.com
post #1 of 14 Old 01-12-2014, 05:51 PM Thread Starter
Cuesoccer24
hey fellow jeepers...I have an issue with the t-case bolts while trying to put on the lowering kit. what I did was hit the bolts with pb blaster for a week straight and then tried to loosen them and finally broke the rust but I looked closer with a flashlight and it looks like the bolt was so rusted that it broke any of the thread in which the bolt goes into to hold up the tranny skid plate. has anyone ever run into this problem before? if so, should I drill new holes into the frame for the new bolts?
Cuesoccer24 is offline
post #2 of 14 Old 01-12-2014, 07:14 PM
booboowv77
To do it correctly from what I've seen (mine came right out no problems) is to cut a hole in the frame and re weld a new nutsert in then patch the frame.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 14 Old 01-13-2014, 07:51 AM
TSEJEEPERS
No need to cut holes.
http://www.jeepforum.com/forum/f9/nu...nstall-390635/
You can find the kit with the nutserts on page 31.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 14 Old 01-13-2014, 02:46 PM Thread Starter
Cuesoccer24
thank you guys...TSEJEEPERS-the guide only has wrangler tj and jk nutserts sizes...is there anything for the yj or is it basically the same?
post #5 of 14 Old 01-13-2014, 06:08 PM
jeepguy85
1987 YJ Wrangler
This was a little farther down in the thread: http://shop.blackmagicbrakes.com/Nut...nt-Kit_c79.htm
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #6 of 14 Old 01-14-2014, 06:09 AM Thread Starter
Cuesoccer24
Thanks man...I'll have to get the other bolts off to see if I need them all the way around which I'm sure I will
post #7 of 14 Old 01-14-2014, 02:35 PM Thread Starter
Cuesoccer24
question though...how do the nutserts stay inside the frame? do they have to be welded in there?
post #8 of 14 Old 01-14-2014, 03:08 PM
fishadventure
nutserts are for no-weld installations in a boxed access application.
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
post #9 of 14 Old 01-14-2014, 03:21 PM Thread Starter
Cuesoccer24
Ya that makes sense thanks man...anyone know of a write up for removal and installation for DIY?
post #10 of 14 Old 01-14-2014, 04:17 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Here http://www.jeepforum.com/forum/f9/nu...nstall-390635/
-April '14- YJoTM- June '15]
The_Goob is offline
post #11 of 14 Old 01-14-2014, 07:28 PM Thread Starter
Cuesoccer24
Thank you goob
post #12 of 14 Old 01-16-2014, 09:11 AM Thread Starter
Cuesoccer24
I was also thinking about this with the lowering kit...wouldn't that change the angle of the engine a little bit and cause the fan to lean or tilt forward towards the engine and possibly cut or shrewd into he belts?
post #13 of 14 Old 01-16-2014, 01:10 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
yes a little but there is some wiggle room. I did a 1" body lift and only had to trim a sliver off the bottom of the shroud to clear. You can also raise/lower the whole radiator with brackets bought or homemade.
Dont let it stop you though
The_Goob is offline
post #14 of 14 Old 01-16-2014, 01:33 PM
superj
i lowered my t-case about 1.5" and its not hitting anything. looks like crap but what can you do until you get a new driveshaft
I don't feel like working on anything at this time so i sold my yj.
superj is offline
