Transfer Case leaking fluid at rear output shaft - JeepForum.com
post #1 of 8 Old 05-20-2010, 12:31 PM Thread Starter
gary1
gary1's Avatar
I have my transfer case off my Wrangler. I set the transfer case on its end for a few moments and a large amount of fluid leaked out around the rear output shaft. Would that indicate bad seals or would it be normal for the fluid to leak out while in that position.
To acquire knowledge, one must study; but to acquire wisdom, one must observe.
gary1 is offline
post #2 of 8 Old 05-20-2010, 12:38 PM
Brown Dog
Vendor
Brown Dog's Avatar
Was it leaking while in use?
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 8 Old 05-20-2010, 12:45 PM Thread Starter
gary1
gary1's Avatar
It wasnt leaking when on the vehicle. There is a seal on the back that looks like it might seal against the drive shaft coupling. That is what makes me think that maybe it would be normal to leak until the pieces are put back in the Jeep.
gary1 is offline
post #4 of 8 Old 05-20-2010, 12:48 PM
Brown Dog
Vendor
Brown Dog's Avatar
You are correct. While you have it out, why don't you replace that seal for about 10 bucks.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #5 of 8 Old 05-20-2010, 12:59 PM Thread Starter
gary1
gary1's Avatar
Yea, I think I will take your advice on that. Thanx...
gary1 is offline
post #6 of 8 Old 05-20-2010, 01:12 PM
Brown Dog
Vendor
Brown Dog's Avatar
I have a theory that if you are looking at an inexpensive part that is difficult to get to, change it. Especially if it could cause lots of damage and/or strand you in BFE.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #7 of 8 Old 05-20-2010, 02:03 PM
glenn-91YJ
glenn-91YJ's Avatar
Bushing
There will always be a little fluid left after draining it. I would suggest changing the bushing in that rear housing as well as the seal. If the bushing is worn it can lead to the seal leaking prematurely. I just changed both of mine. I used a 30mm socket to drive the old bushing out. Anything larger to drive the new bushing in is fine.
glenn-91YJ is offline
post #8 of 8 Old 05-20-2010, 02:41 PM
Area.3.Fiftyone
There is no need to change the bushing unless it's galled or worn oversize.
I would definitely change the seal though. It's cheap insurance.
If you don't change it now, it's no big deal to drop the rear shaft and replace it later. It's not like it's really hard to get at like some other seals (input shaft seal for instance) while it's in the vehicle.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
Changing Output shaft rear oil seal on transfer case Cards89YJ YJ Wrangler Technical Forum 4 02-08-2010 05:08 PM
Modified NP231 transfer case output shaft (feedback requested) snsmith86 TJ Wrangler Technical Forum 12 09-21-2009 03:03 PM
What is the part number for the output shaft seal on 231j transfer case?... zachgregg TJ Wrangler Technical Forum 4 07-09-2009 11:05 PM
Transfer Case Rear Output Shaft Wanted gotriver YJ Wrangler Technical Forum 8 03-17-2009 10:37 PM
Transfer case output seal leaking. Any write-ups on how to change it? TheMightyGoat TJ Wrangler Technical Forum 0 05-07-2008 05:36 PM
