Transfer Case Leak Help - JeepForum.com
post #1 of 8 Old 07-14-2011, 02:08 PM Thread Starter
95_Sahara
Is this just the Pinion Seal that needs to be replaced? Also I'm taking a 7hr round trip this weekend...should I be ok?
95_Sahara is offline
post #2 of 8 Old 07-14-2011, 02:11 PM
jeepbluexj
looks like the seal went happen to mine before and i drove from jersey to ohio with it leaking i was fine just top off the fluid and check it when u get to where your going
Just Empty Every Pocket
98 Cherokee classic
jeepbluexj is offline
post #3 of 8 Old 07-14-2011, 03:11 PM
mrdeath2000
DEAR LORD!!! Did you pull that driveshaft from the bottom of the ocean???
pickup a seal and a bushing for the TC. I read in other articles they can be a PITA to remove/install, but if you have another vehicle, once you get it off, take it to a local trans shop and they can R&R the seals/bushings for free or <$20.
Just make sure when you get your seal and pull the slip yoke out, feel the yoke and make sure its smooth and not have any burrs that will tear up your new seal. then make sure the seal is the right size on the yoke and not too big.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #4 of 8 Old 07-14-2011, 03:43 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Exactly what I was thinking.
Personally, I'd let it go. Just keep the fluid topped up in the case.
Think of it as an asset, not a liability. Instead of thinking "leak" (bad) think "proactive rust control system" (good) instead.
Seriously, it's not as bad as it looks. Do the repair as mrdeath2000 suggested, but it can wait until you're ready.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 8 Old 07-14-2011, 03:45 PM
g4x4xgeoff
that's vermont rust for you!
my jeep was from vermont...looked just like that. 90% new metal, and it's somewhat better....somewhat....
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #6 of 8 Old 07-14-2011, 03:46 PM
mazyj
I agree with Mean Max. Mine has looked like that for years and I just check the fluid every once in a while. As well as rust control it also ensures the fluid is always fresh!
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #7 of 8 Old 07-14-2011, 03:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
See? You can win TWICE!
Max
Mean Max is offline
post #8 of 8 Old 07-14-2011, 04:36 PM Thread Starter
95_Sahara
Hell Yeah! Vermont Rust..The Rest of it doesn't look like that, frame and body are in great shape. lol..So had to drive to Sears and pick up a 30mm (only friken socket I don't own) and picked up fluid to only find the fluid level is fine....Guess I will just keep an eye on the level. Time to return the fluid.
YJ Transfer Case Leak jeephobbie57 YJ Wrangler Technical Forum 6 03-20-2011 08:26 PM
Transfer case leak doherty80 YJ Wrangler Technical Forum 0 03-27-2010 01:30 PM
Transfer case leak djl7780 TJ Wrangler Technical Forum 38 03-01-2010 02:13 PM
Need help with transfer case leak SmackLayer TJ Wrangler Technical Forum 10 08-15-2009 09:26 PM
Transfer Case Leak j2roch TJ Wrangler Technical Forum 2 07-14-2009 07:36 AM
